September 17, 2026, 03:25:26 am
Hoffman Amps Forum image Author Topic: Plexi 50 troubles  (Read 65325 times)
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
Re: Plexi 50 troubles
« Reply #100 on: April 30, 2019, 08:16:14 pm »
I got the cellphone playing through the PI   :icon_biggrin:    the volume is low thou. Presence pot works with it !
Oh and I forgot to mention the cap cans are 50uF/50uF/500v
For you last post, I'm a bit lost at:
> NO signal Tap A VDC, BOTH PA tube currents
Read VDC, but how do I get the current ? Cathode resistor ?
> 5mA
Is it .005 ?
« Last Edit: April 30, 2019, 09:12:33 pm by uki »
https://soundcloud.com/ukiuki
Offline Tony Bones
  • Thread Killer
« Reply #101 on: April 30, 2019, 10:03:56 pm »
Most resistors, 6 caps, volume pots, all sockets, PT, OT, input jack, ohms switch, all from the old amp,
I'd go back and make sure that the contacts on all of those are clean, including the ohms switch. Deoxit helps if you can get it easily. The odds of this fixing the problem are not great, but not tiny either.
this thead.
Yeah, I read that thread three years ago.  :laugh: Things change ...
About the light inside the tubes. I did replace those tubes few days go, the previous ones were lighting up, some of the guys said they were arcing.
The video with lights off, both volume knobs at 50% LOUD.
&feature=youtu.be
That blue glow is totally not a problem.
« Reply #102 on: May 01, 2019, 04:30:24 am »
Can we get this amp back to a stock Plexi schematic?
1. Are you using the OT screen taps? If so, do you know for a fact that you have them wired correctly? A screen tap must be used with its corresponding plate tap. If you are using the screen taps I highly recommend that you NOT use them. Just tape them off and wire the tube screens just like a Plexi schematic.
2. I'm also suspicious of your high resistance bias balance circuit. I suggest you go back to the simple Plexi bias circuit until this weird problem is sorted. You can always fancy it up after the amp is working properly.
Once you do these two things we'll be in a better position to try to solve your issues.
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
« Reply #103 on: May 01, 2019, 07:27:17 am »
Feed the amp section with the plate of the first ax7, disconnecting everything else in the path.
It ll give you a good clue.
P.S.: call me Alvin.
« Reply #104 on: May 01, 2019, 09:45:33 am »
yes .005
even with low input, did the volume change up/down?
Offline uki
    • Uki's Guitar Trip
« Reply #105 on: May 01, 2019, 01:58:06 pm »
Yes ! Doing it already !  Balance circuit removed !
1. Are you using the OT screen taps? ...
Never connected them.
yes .005
No volume changes while playing through the PI , did it run for about 10 mins.
ADD the 2 current values together, then ADD 5mA
OHM a resistor value R = V/I
OHM a Power value for your R, then multiply * 2 (close works:)
Find your Resistor, make it.
Ok let me see if I got this:
read voltage DC in tap A,  460vdc ish
read current for PA tubes(across cathode resistor)  0.021mA
0.021 + 0.021 + 0.005 = 0.047
460 / 0.047 = 9787.23404255
that is 10k resistor.
I'm not sure about the power, how to get there?
Now that you got your Resistor, clip 1 side to the last PS Tap, clip the other to ground.
PULL ALL TUBES
Clip meter across your resistor, set for VDC
Power up, voltage should be close to full stable within 30 seconds.
IF it’s about the same as you measured for tap A AND there isn’t any smoke, let it COOK for 5min, walla, 1/3 of amp tested!  Kinda
the music to PI should decide another 1/3rd
By last tap you mean tap E ?
« Reply #106 on: May 01, 2019, 02:09:17 pm »
22W *2, so 50W  P=E * I.  You can get by for a real quick test with ~~30W
Attach to TAP B, quick measure, look for HOT or smoke.  What this does is "simulate" the tube load the PS "see's".  I do this before I EVER plug in a tube.  I'm about 90% sure your PS is ok, unless you used unknown, old caps.  So, keep doing the other stuff 1st.
I'm also about 90% sure it's from PI to speaker
here's a handy ohm chart
Offline uki
    • Uki's Guitar Trip
« Reply #107 on: May 01, 2019, 03:01:14 pm »
> P=E * I
What is E ?
I don't have 10k 50w resistor,  I got 12k 5w , 10k 10w, 15k 10w,  330r 25w
PS filter caps are all new, this
Now the PI caps are old , really old. the little brown caps look in the pics.
« Last Edit: May 01, 2019, 03:05:05 pm by uki »
« Reply #108 on: May 01, 2019, 03:51:50 pm »
really old
Now those are some oldie moldy!!
I would unsolder the "right" side and see if they are leaking DC volts (C8, C11, C12)
measure VDC from the right side (unsoldered) to ground, anything more than ~~ 20mV DC I'd replace.  with new ones  :icon_biggrin:
E is volts, same as V.  depending on age we either learned it as E or V or HT, or... :think1:
« Last Edit: May 01, 2019, 03:56:16 pm by shooter »
Offline uki
    • Uki's Guitar Trip
« Reply #109 on: May 01, 2019, 04:23:35 pm »
I did read again the voltages for PA after removing the bias balance mod,
I did notice this since the first time the amp was working, while reading V4 pin 3 it does a big noise, meter goes crazy for a second then the voltage show up. Did lost one cheap meter reading this pin, while ago.
V4 P3  477 vdc
         4  472 vdc
         5   -53 vdc
         6   -53 vdc
         cathode resistor   0.002mV
V5  P3  477 vdc
          4  475 vdc
          5   -53 vdc
          6   -53 vdc
          cathode resistor  0.011mV
I did notice a lot of downgrade in tone with the rollback.
We have done this before here and here, they did ok back then, could they drift in this time? Gonna get it again anyway.
« Last Edit: May 01, 2019, 04:33:23 pm by uki »
« Reply #110 on: May 01, 2019, 05:20:07 pm »
drift in this time?
should be good, just next order, add a couple caps
« Reply #111 on: May 01, 2019, 05:57:20 pm »
-53v is way too high for el34s. You need to be between -40 and -45.
Offline uki
    • Uki's Guitar Trip
« Reply #112 on: May 01, 2019, 07:05:18 pm »
I got those items in place !
Now it is  at -46 V4 current is .030v already, while V5 is only .017v
here is about the point where the previous tubes started to red plate,
this is why the bias balance control.  This pair of tubes are unmatched.
Nodes A and B at 464v
« Reply #113 on: May 01, 2019, 08:02:17 pm »
swap the tubes around, does the current follow the tube or stay with the socket?
Offline uki
    • Uki's Guitar Trip
« Reply #114 on: May 01, 2019, 08:16:39 pm »
Does not stay with the socket, same readings as before.
From this point Sluckey want to find out the cause of that 70v drop while playing.
« Reply #115 on: May 01, 2019, 08:22:36 pm »
This tells me you are way off on match, Follow Sluckey, when you get time try n get 2 tubes +/- say 5mA instead of the 13mA you got now.
my thought, when you hit that HOT tube hard, it's cooking at 3X max plate
Offline uki
    • Uki's Guitar Trip
« Reply #116 on: May 01, 2019, 08:51:37 pm »
I only have those previous tubes, the EH matched pair, but I dunno if they are good. The amp was playing ok with them. But the Mullards sound way better !
« Reply #117 on: May 02, 2019, 08:41:03 am »
V5 was .017mA, keep that one.  Then take your "suspect" others and put them in 1 at a time.  use the one that get closest to .017.
what sounds good won't count til you are happy the amp is working  :icon_biggrin:
Offline uki
    • Uki's Guitar Trip
« Reply #118 on: May 02, 2019, 05:20:39 pm »
I got the tubes matched(almost) EH on V5 with .018v and Mullard on V4 with .019v !
« Reply #119 on: May 02, 2019, 05:50:05 pm »
SWEET, now go fix your amp  :icon_biggrin:
where do the #'s fall, idle no signal
Offline uki
    • Uki's Guitar Trip
« Reply #120 on: May 02, 2019, 06:09:07 pm »
I'll get the big resistor next week!
What you mean with where do the #'s fall, idle no signal  ?
« Reply #121 on: May 02, 2019, 06:30:40 pm »
TAP A vdc
TAP A * .017  = tube dissipation at idle
tap A *.018
so I take it it plays ?
IF so, ONLY play CLEAN, 1 channel at a time, play long enough to be comfortable it does or doesn't do the volume up/down thing.
Offline uki
    • Uki's Guitar Trip
« Reply #122 on: May 02, 2019, 07:06:21 pm »
Little variation after powering off on.
A 458vdc  *  .018 = 8.2w
    458        *  .017 = 7.7w
It does not change volume while playing it clean, both channels checked, one at a time.
before this the volume behavior was happening when volume was at the point where the amp start to OD, about volume 3.
In the last video the volume change did not happen.
Also I did watch the tap A while playing at lvl 2(clean), it does drop almost 10v. PA tubes go might hot, can't keep touching.
« Last Edit: May 02, 2019, 08:35:22 pm by uki »
« Reply #123 on: May 02, 2019, 09:26:44 pm »
Adjust the bias to increase tube current to 36mA (36mV across the cathode 1Ω resistors). How does it behave and sound?
Offline uki
    • Uki's Guitar Trip
« Reply #124 on: May 03, 2019, 09:29:41 am »
Current set at 36mA in the hotter tube(Mullard) V4, Tap A is reading 450 vdc  the voltage drop is now smaller but with peaks of 50v
the current goes up about double while playing. No red plate in about 10-15 mins.
Now about the tone, not very pleasant , probably because of the different brand of tubes, the EH tubes doesn't sound good in comparison with the Mullard. EH tubes sounds more harsh and dry, Mullards more round and warm.
The volume random change is happening with both channels open and at about 3, where the OD start, bellow that doesn't happen.
The volume went up/down twice just as the volume was increase to about 3 and strumming the strings hard. So I did turn down the volume immediately. With the volume bellow the amp does a clean sound.
« Reply #125 on: May 03, 2019, 09:41:09 am »
Temporarily disconnect the NFB. Sound any better?
Offline uki
    • Uki's Guitar Trip
« Reply #126 on: May 03, 2019, 10:15:45 am »
W/o the NFB the amp does sound better, the volume change did not happened, so it is something in that part of the circuit, a cap maybe?
The amp goes a bit microphonic thou.
« Reply #127 on: May 03, 2019, 10:36:20 am »
Reconnect the NFB. Then swap the OT primary plate leads. What happens?
Offline uki
    • Uki's Guitar Trip
« Reply #128 on: May 03, 2019, 11:11:34 am »
Amp does whistle right the moment the standby is engaged. I did turn off right the way.
« Reply #129 on: May 03, 2019, 11:47:09 am »
Keep working with Sluckey
this is a fwiw;
this amp
http://el34world.com/Forum/index.php?topic=20104.msg210740#msg210740
I never did get it "fixed"
at clean, played fine, guitar or music, the minute you hit OD things when sideways.
I changed enough pieces, spent enough scope time to be reasonable convinced my OT is to blame, core saturation, weird impedance stuff that needs spooky math  :dontknow:
« Reply #130 on: May 03, 2019, 12:41:06 pm »
Well, put the OT primary plate leads like they originally were.
At this point I would buy a real Marshall 50W OT. Hoffman still has them.
Offline uki
    • Uki's Guitar Trip
« Reply #131 on: May 03, 2019, 12:54:06 pm »
Can't buy over sea with the current currency rates,   1 USD to BRL 3.93947
Anyway, so it is the OT that doesn't go well with the rest of the amp ?  Bad idea to keep playing with it?
« Reply #132 on: May 03, 2019, 02:20:01 pm »
how much are tubes , and possibly PS worth to you
You're now a highly qualified troubleshooter, fix some amps and get some money  :icon_biggrin:
fwiw, the amp I mentioned, it's still out being used, just not overdriven
Offline uki
    • Uki's Guitar Trip
« Reply #133 on: May 03, 2019, 02:49:47 pm »
Not a bad idea !!    :icon_biggrin:
The OT was probably for a pair of 6V6 and it is probably rated for 20-30W tops, that is my own conclusion, because the volume past 4-5 doesn't increase volume, the amount of distortion tells something is out of place. The original amp had a tube rectifier so more voltage drop, that is what makes me think this. Here another thing, while running at 21mA it does sound much better, does it add up clues for you?
Ok new OT for this amp. Gonna put it to rest for now !
Thanks a lot guys , your help is very much appreciated !!
 :happy2:
« Reply #134 on: May 03, 2019, 03:53:57 pm »
That's not what I'm saying. I said, "At this point I would buy a real Marshall 50W OT." Parts substitution has always been a valid troubleshooting technique. Doesn't always fix the problem though.
If you suspect that OT may have been for a pair of 6V6s, then you must also suspect the PT was for a pair of 6V6s. You had the whole amp. Don't you know what tubes were supposed to be in it? If the iron really was meant for 6V6s then just put 6V6s in it and call it a Plexi6V6. Mine sounded pretty good!  :icon_biggrin:
Offline uki
    • Uki's Guitar Trip
« Reply #135 on: May 03, 2019, 04:44:56 pm »
I dunno if it was running a pair of 6v6  :dontknow:  The old Fidelius came without, the power tubes and rectifier, It had on one 6SL7 one 6SN7 one EF86 and one 12ax7.
About the transformer, here is a pic of print.
And a schematic I draw for the power section, maybe wrong.
« Last Edit: May 03, 2019, 04:56:11 pm by uki »
Offline Tony Bones
  • Thread Killer
« Reply #136 on: May 03, 2019, 06:22:45 pm »
That iron certainly looks big enough to support 6L6/KT88. The vintage amps I've found that were set up for 6V6 usually had much smaller OT.
« Reply #137 on: May 03, 2019, 06:25:01 pm »
the 500 cathode R is kinda common on 6V6, my notes say 500-750
I got 270 - 330 for EL34's.  BUT those are ballpark based on plate V
and the Iron like tony said is BIG
you could scrap the fixed bias and try self biased.  you will change "volume" some, and tone will change, with self bias you usually set to 80-100% dissipation since the harder you play the less likely you smoke important parts
« Reply #138 on: May 03, 2019, 07:12:08 pm »
went re-reading...some
32 * 32 = 1024    1024 * 8Ω = 8192Ω
8k is kinda 6V6 value, 34's is kind of 3.5k, pointed out by PDF64 for fixed bias
so I would be inclined to put a 4ohm speaker on the OT and play clean, if all's good, move into OD and see if it sounds better.
I doctored up this datasheet for  "options" til you get a new OT
the UL data 20% 43% will be a guess, all the modern UL's I've bought are 40%, but that's NOT scientific  :icon_biggrin:
« Reply #139 on: May 03, 2019, 07:58:45 pm »
If pin 1 was not connected to anything then it ain't an EL34.
Offline uki
    • Uki's Guitar Trip
« Reply #140 on: May 03, 2019, 09:00:38 pm »
Pin 1 was connected with pin 8.
« Last Edit: May 03, 2019, 09:05:00 pm by uki »
« Reply #141 on: May 04, 2019, 05:09:02 am »
Bear in mind that generic 'off the shelf' OTs might have been marketed for various tube sets, eg the Radiospares Deluxe used by Marshall for the early JTM45 listed EL34, KT66, 6V6, 6L6, EL84 as suitable tube types (though that has multiple primary and secondary winding taps / arrangements available)  https://imgur.com/a/zLmbj
Offline uki
    • Uki's Guitar Trip
« Reply #142 on: May 14, 2019, 01:20:06 pm »
Is this model 40-18025 a suitable OT for the amp?
« Reply #143 on: May 14, 2019, 01:41:02 pm »
I don't know.     :dontknow:    :think1:   Are you building a 50 watt Marshall amp?  :wink:
Offline uki
    • Uki's Guitar Trip
« Reply #144 on: May 14, 2019, 07:05:42 pm »
 :w2:
It is built already, the plexi50
... I said, "At this point I would buy a real Marshall 50W OT." Parts substitution has always been a valid troubleshooting technique. Doesn't always fix the problem though.
That is what I been thinking. To try an OT designed for this amp.
« Reply #145 on: May 14, 2019, 08:20:21 pm »
I think the dollar might weaken soon, get a good exchange rate, buy it, play it  :laugh:
