September 16, 2026, 10:20:11 am
Hoffman Amps Forum image Author Topic: Homebuilt JCM 800 to SIR #36 mods  (Read 60068 times)
Offline Tone Junkie
Re: Homebuilt JCM 800 to SIR #36 mods
« Reply #50 on: January 24, 2011, 09:19:52 am »
Does putting it across the plate and cathode or across plate  resister do the same thing though thats what Im wondering. sorry I know another stupid rookie question but I dont know .        :angel
Thanks Bill
Offline JayB
« Reply #51 on: January 24, 2011, 10:24:14 am »
Thanks Bill
Sort of. Across the plate and cathode, it's passing the ac signal to ground through the cathode resistor and by pass cap. Across the plate resistor, it's not allowing the ac signal to develop across the plate resistor in the chosen frequencies that cap effects. The end result is the same.
You're going to hell faster than Britney Spears running to a Barber shop
Offline Chris Mitlyng
« Reply #52 on: July 27, 2016, 02:58:40 pm »
here are some pics from my afd build.
let me know if you see anything wrong.
this amp rocks and oh my god is it loud!
thanx to all who have helped me build this thing.
Rockgod212,
Do you have the most recent schematic for the amp build? I am looking to build my own and cannot access the Metroamp forum.
« Reply #53 on: July 27, 2016, 03:48:25 pm »
It's been 6 years since Rockgod212 has logged onto the forum.
Offline MFowler
« Reply #54 on: July 28, 2016, 10:06:40 am »
I built DarkBlueMurder's (DBM) version of a #39 and that amp is fantastic, built a second with same results and onto a 3rd for myself because I can't stop smiling whenever I play the amp I sold to my friend.
It's a Marshall JCM800 2203 the 100w version with extra gain stage and cathode bypass capacitors switching for boost.  I also add Resonance/Depth pot to get some bass back in.
Mark
« Reply #55 on: July 28, 2016, 10:53:39 am »
Thanks for sharing Mark.
If nothing else, it made me go back and save that schematic and look it over.
Kinda reminds me of Bogner's Ecstacy red channel preamp topology...how do your preamp voltages compare to these?
http://el34world.com/charts/Schematics/files/bogner/bogner_ecstacy.pdf
Offline MFowler
« Reply #56 on: August 02, 2016, 06:38:39 am »
Sorry I checked to see if I had a voltage chart on my two builds and do not.  When  I complete number 3 I will save a voltage chart and post.
« Last Edit: August 02, 2016, 06:40:42 am by MFowler »
