September 17, 2026, 05:27:20 am
Hoffman Amps Forum image Author Topic: Wierd Fender Champ II issue  (Read 5389 times)
Offline reggiepe
« on: May 10, 2019, 08:44:12 am »
Hey all, I have a strange one on the bench this morning. I have an early 80's Champ II that had been abandoned for quite some time and I am going through it to check everything..plus since I have it open, I am going to refresh the caps in there. I pulled a pair of 12ax7's and a pair of 6V6's from a working amp, so I know that isn't the issue. So the weird thing is....I powered it up slowly on a variac and saw no visible issues. Checked the voltages and all seem to be within spec. Got no sound....strange thing is, when I turn the power switch off and the caps are draining along with the filaments cooling down, I get sound until it slowly dissipates into nothing. Did this multiple times and get the same result. Sound last for maybe 5 - 7 seconds and then fades to nothing. Any thoughts from the collective?
Re: Wierd Fender Champ II issue
« Reply #1 on: May 10, 2019, 08:57:20 am »
I wouldn't fret over the symptoms til these are new
got a scope?
Offline reggiepe
« Reply #2 on: May 10, 2019, 09:47:49 am »
got a scope?
Nope, no scope in the arsenal yet.
I'll add too, that the sound that comes through sounds good and full all controllable by the EQ section and master volume.
Offline st
« Reply #3 on: May 10, 2019, 02:27:06 pm »
Please measure and post voltages. Especially plate and bias voltage of the 6V6s.
And just to be sure, you haven't changes any caps yet, did you?
Offline reggiepe
« Reply #4 on: May 10, 2019, 02:43:27 pm »
Voltages are within spec of the schem voltages. No, I just opened it up to take a look and to verify all caps against the schem and to make sure there were no crispy resistors. Just placed the order for caps a few hours ago.
Offline st
« Reply #5 on: May 13, 2019, 12:46:51 am »
Then put them in first and try again...
