September 16, 2026, 11:53:30 pm
Hoffman Amps Forum image Author Topic: Bonnet Box conversion 4x EL84s  (Read 19554 times)
Offline shaun
Re: Bonnet Box conversion 4x EL84s
« Reply #50 on: August 28, 2019, 06:38:26 pm »
Ha! Yeah, I'm bleeding all over lately.
I'm also interested in why there is a 33k to ground off the B+ feeding the EF86 plate - it's shown connected to the 40uF power filter cap. I have only 60v at the EF86 plate, so it seems possible that 33k to ground is bleeding off voltage that I need to make the EF86 perform how I'd like.
Care to take a stab at that? :)
With gratitude.
« Reply #51 on: August 28, 2019, 06:46:00 pm »
 :l2:
I'll just call it a bleeder, for now  :icon_biggrin:
I'd have to do way to much reading to "get" why direct coupled.  Until you get their I wouldn't mess with the plate volts.  I might be looking for an alterative version that looks closer to what the rest of the modern world uses  :laugh:
Offline shaun
« Reply #52 on: August 28, 2019, 07:18:09 pm »
Hmmm. Well, a little research shows DC tube amps were/are a pita to deal with. So I'm gonna reconfigure this as a typical 4 x EL84 amp and use the EF86 as pre and 12AX7 as PI.
I'll go look at a few Vox schematics and take it from there.
Thank you!
ps. why are most of the emoticons on this forum expressing rage, frustration, and confusion? I've NEVER felt any of those things when banging my head against the wall:).
With gratitude.
« Reply #53 on: August 28, 2019, 07:27:43 pm »
WHAT ARE YOU TALKING ABOUT! The most negative emoticon in this entire thread is "I don't know". And that ain't negative.
« Reply #54 on: August 28, 2019, 08:31:40 pm »
> There is a .002 cap running to a 100k resistor, both ends connecting to the B+.
NO. One end to B+. Other end to plate. Not the same.
The result: low frequencies see 180k load, high frequencies see 180k||100k= 64k load. Gain falls to about 1/3rd. Gain starts to fall near 180k against 0.002u or 460Hz.
Pentode plate is *direct coupled* to twin-triode grid. You would think this would be bad. But look at the very large cathode resistor under the 12AX7. About 100X higher than ground-grid self-bias value. Instead the AX7 grids are at maybe +100V, so the cathodes are near +100V. 100V in 68k is 1.5mA. Two cathodes, so each may have 0.75mA. In 100k plate load this is 75V drop. Given >250V of B+ (supply, not plate!), everything fits.
> I want to insert a modest tone stack after the EF86
Eh. We need to pass the DC through. Also the 10k:330 NFB divider is *around* your proposed tonestack, and NFB will try to cancel what the tonestack does.
Offline shaun
« Reply #55 on: August 28, 2019, 09:22:57 pm »
Yes, PRR, that makes sense. It didn't occur that the NFB would do that. Thank you!
With gratitude.
Offline shaun
« Reply #56 on: September 13, 2019, 04:48:17 pm »
A final update on how the Bonnet Box rebuild went. Thank you again for the great feedback given on this forum.
The attached schematic shows most of the mods.
I kept the power section, although I changed the PT secondary resistors to 75ohm 5watters, and the GZ34 to a 5U4 - this was to reduce plate voltage at the EL84s and the PI. It's worked nicely....so far.
The PI was redesigned in accordance with Sluckey's drawing of the Vox AC-30.4, which also uses a 12ax7 PI - that schematic is easy to find if interested, and it matched the quad EL84s nicely. Of course, this necessitated inserting coupling caps between stages, instead of the original design. Once those caps were in place, I was free to add the 18 Watt Tremolo tone stack (super simple for a newbie like me).
The EF86 input was reconfigured it for Hi and Lo imp (not shown on schematic). I reduced the cath res and added a 25uF bypass cap. Also, the schematic doesn't show it, but I removed the 33k res that goes to gnd off Node 3 - it was bleeding too much voltage away from the EF86, and once it was removed, the PV of the EF86 went from around 46v to 110v.
I removed the NFB, and I floated the filament AC with two 100ohm res to gnd, thus removing the hum balance pot, which I didn't like much.
There was a bunch of extraneous stuff removed, but I reconfigured the octo plug to serve the control panel. Control panels are a PITA, largely because they entail many more logistics when removing and re-testing the amp over time. However, the PT has a dedicated 6v winding for the idiot light, so I used that, running it up to the control panel.
The inputs and control pot connections were run, via shielded RCA cable, up to the control panel - more screwing around that took forever. It also introduces all sorts of hum, and the amp still has a little more than I'd like, so I keep checking for ground loops etc.
The original amp had a woofer, two mids, and a tweeter. I kept the woofer and a hi-mid (both 8ohm) to give me the 4ohm load the amp output was designed for. I experimented with the crossover filter, and it still works well. I know guitar amps don't usually have this type spkr config, but it's fun to experiment, and it means that when an MP3 player is plugged into the Lo-Imp input, the audio quality is a bit fuller than a single spkr would offer.
Finally, the thing sounded exceptionally loud and exceptionally good, breaking up beautifully right about the same time my ears started to bleed. So I added a Type 3 Master Vol, inserting a 1M audio taper pot right after the 0.1 coupling caps coming off the PI.
The MVol works, but there is a problem: it turns the vol all the way down okay, but it behaves sort of like a linear pot - the total volume kicks in with barely a quarter turn of the pot. This is a problem with some Fender amp volume pots - usually, changing those pots, which were linear, to audio taper fixed the problem. But this is already an audio taper, so I'm not sure what's up, unless the pot is mislabeled. Any suggestions very welcome.
That's about it. You'll see I rebuilt the cabinet from the old bonnet box in an attempt to retain some of the old styling, but it quickly becomes a logistical nightmare to do this sort of thing - headaches loom at every turn. This is why the control panel if full of patched holes - it took about ten tries to figure out how the thing would go together, as opposed to using a purpose-built cabinet. The results ain't pretty. Thus, Ugly Betty was born. And let's face it, the Bonnet Box was about as ugly as a stereo could get in any case. But I do admire the workmanship I encounter when modifying such a cabinet.
Cheers all.
With gratitude.
