September 14, 2026, 09:53:47 pm
Hoffman Amps Forum image Author Topic: Ryan Colgan's Steel String Slinger Info  (Read 64908 times)
« on: July 06, 2019, 10:03:37 am »
Ryan Colgan has designed a set of eyelet boards for the Dumble Steel String Slinger
It is a set of seven boards
I have been making these boards for customers
I condensed the seven boards into two .diy files using cut lines
I have a max length of 21 inches for custom boards and so I had to split the 7 boards into two long boards
The .diy files show the cut lines where I cut the boards apart after drilling them on my CNC machine
I attached an image below to show what the two long boards look like.
Ryan has all his project info on Github here.
https://github.com/colganr/steel-string-singer-sn-002
Browse through all the folders to see all the info he has there
The color image of the full layout is sized down here because it was huge
Here's a link to all the full sized images
https://tinyurl.com/yym4d476
Here's Ryan's web site
https://www.thetonegeek.com/
I added Ryan's .diy files to the Misc DIY library here
https://el34world.com/charts/DiyLayoutCreatorFiles.htm
I added a new catalog page to my web store with Misc eyelet boards
These boards can be ordered on this page
https://hoffmanamps.com/MyStore/catalog/MiscEyeletBoard.htm
The shipping calculator will not be correct for these boards because they get chopped up into 7 shorter boards.
« Last Edit: July 08, 2019, 01:32:54 pm by EL34 »
Re: Ryan Colgan's Steel String Slinger Info
« Reply #1 on: July 06, 2019, 10:05:02 am »
These five boards are in the SteelStringSlinger2.diy file in the DIY library- Misc folder
« Last Edit: July 08, 2019, 12:46:03 pm by EL34 »
« Reply #2 on: July 06, 2019, 10:12:55 am »
These two boards are in the SteelStringSlinger1.diy file in the DIY library- Misc folder
« Last Edit: July 08, 2019, 12:46:14 pm by EL34 »
« Reply #3 on: July 06, 2019, 10:20:47 am »
This link has images and close ups of Ryan's .diy files
https://github.com/colganr/steel-string-singer-sn-002/tree/master/Circuit/Board%20JPGs%20and%20PDFs
Ryan has a YouTube playlist of the Steel String Slinger here
https://www.youtube.com/playlist?list=PL7cXUZ8g7NhQ-m8TfABf82qVsaGDDUorQ
« Last Edit: July 12, 2019, 09:11:29 am by EL34 »
« Reply #4 on: August 22, 2020, 09:34:25 am »
Ryan has updated his SSS DIYLC layouts
There is a version 1 and Version 2
Version 2 is a revision of version 1
Looks like he just moved some holes around in re-vision 2?
Both of these versions are in the DIYLC library here
Look for R1 and R2 versions of the Steel String Slinger
https://el34world.com/charts/DiyLayoutCreator/files/Misc_Diy_Files/Misc_Diy_Files.htm
Offline dan46n2
« Reply #5 on: November 03, 2020, 08:40:35 pm »
Does anyone know if the tall turrets can be installed on these Hoffman SSS boards that are drilled but without eyelets installed?  Didn't know if the hole size was the same or not?
« Reply #6 on: November 04, 2020, 06:20:13 am »
Eyelet layouts do not convert to turret lug layouts most of the time
Go here and read more info on that
https://el34world.com/Forum/index.php?topic=23699
