September 15, 2026, 09:16:23 pm
Hoffman Amps Forum image Author Topic: Low filament circuit voltages  (Read 7459 times)
Offline Dead Short
« on: July 14, 2019, 07:04:42 pm »
First time build! I just completed my 1st amp build. A simple 5f1 Tweed. I wanted to thank all on this board as you all saved me tons of time and mistakes. I made a few mods to it along the way. I added a NFB toggle, a independent on/off switch and a three way rotary  switch for 4/8/16 ohm speaker selection. Ran out of room on the chassis.  I checked continuity, grounds and voltages all the way around. Everything was spot on except the ac voltage on the filament circuit. It measured 3.4 vac not 6.3? I used a Classictone 40-18019 PT.. (green wires). I fired it up and the amp works perfectly---no humms WSE!   Any harm in running at 3.4 vac to heaters?  Everything seems to be in order otherwise.  Thanks in advance
Re: Low filament circuit voltages
« Reply #1 on: July 14, 2019, 07:28:28 pm »
Don't measure filament voltage with one probe on chassis because that only measures half the voltage. Instead, measure across the tube socket, ie, for the 6V6 put one probe on pin 2 and the other probe on pin 7. Then you'll see all the filament voltage.
Offline Dead Short
« Reply #2 on: July 14, 2019, 08:18:49 pm »
Thanks Sluckey,  all the reading and vids I watched I didn't pick that bit up...I knew it was something I should have known..Amp sounds great. I am now deflated since that project is done..It was a ton of fun building it. Just a matter of time before I start a new build, but a bit more complex...although I dont need another amp...any suggestions on a next build thats fun and affordable?
« Reply #3 on: July 14, 2019, 08:34:49 pm »
Hoffman has several nice projects. Or you may find something interesting on my website. You may find that you always need just one more amp.  :icon_biggrin:
How 'bout showing us some pics of your build? We like that stuff.
Offline Dead Short
« Reply #4 on: July 15, 2019, 06:06:33 pm »
Pics
Offline Dead Short
« Reply #5 on: July 15, 2019, 06:08:49 pm »
Pics
Offline Dead Short
« Reply #6 on: July 15, 2019, 06:10:26 pm »
More pics
Offline Dead Short
« Reply #7 on: July 15, 2019, 06:14:55 pm »
Waiting for 112 -  Tweed Cab to come in, (vintage Jensen C12R speaker)
then touch up cosmetics - let her rip
Offline Dead Short
« Reply #8 on: July 15, 2019, 06:16:54 pm »
Last pic.
« Reply #9 on: July 15, 2019, 07:53:11 pm »
Wow! Wish my first amp had looked that good.
One cosmetic tip... Put those star washers (switches and jacks) on the inside of the chassis for a cleaner look.
Offline Dead Short
« Reply #10 on: July 15, 2019, 09:31:19 pm »
Thank you Sluckey!
I noticed that washer foul!  Moving those is on my list. I was focused purely on mechanics and nothing of cosmetics when I put those things on the outside.  I was in a  zone. 🎯
This amp really sings I am very happy with the outcome.
I will post more pics when clean it up and mount it a cab....
Offline Dead Short
« Reply #11 on: July 28, 2019, 11:55:18 am »
Just for the heck of it and since I have the 15w PT and OT(40-18031/40-18019) I am going to swap some tubes. If I use a change the rectifier to a gz34 and output tube to a 5881 and switch the impedance switch to the 16 ohm  tap, will  I have to re-bias the cathode resistor or could I just plug and play?
« Reply #12 on: July 28, 2019, 11:59:43 am »
> change ....output tube to a 5881
What do you gain? 5 Watts to 9 Watts? That won't put your record in the Top Ten.
Offline Dead Short
« Reply #13 on: July 28, 2019, 12:33:49 pm »
True that! Especially since my playing is novice at best😅.  I gues I am just bored and looking for something to tinker with...maybe I will build another amp entirely instead and give it to someone who can play but can't afford a beauty!
Offline Dead Short
« Reply #14 on: July 28, 2019, 12:58:19 pm »
 :laugh:
