September 14, 2026, 05:11:52 am
Hoffman Amps Forum image Author Topic: Mixing resistors  (Read 7311 times)
Offline Toxophilite
Mixing resistors
« on: July 21, 2019, 03:36:57 am »
If I want to get a bit more preamp volume into the PA of a basic 2 channel non-reverb deluxe Ab763 build, can I lower the value of the mixing resistors, say to 180k each? Is the 220k used by fender absolutely necessary?
Re: Mixing resistors
« Reply #1 on: July 21, 2019, 03:49:09 am »
It wouldn’t help.
As long as they’re high enough not to excessively load the preceding stage, there’s a 6dB (signal level halved) across them, whatever their particular value (provided) they’re both the same).
As their value is reduced much, eg below 100k, the preceding stage will become loaded, reducing their gain and max signal swing.
If made a lot larger, eg above 470k, they will start to lose more than 6dB, due to the input impedance of the LTP / power amp (>2M).
Offline OrganicEffects
« Reply #2 on: July 21, 2019, 11:04:24 am »
What about lowering the grid stoppers on the PA, or hanging a larger resistor off the bass pot?
« Reply #3 on: July 21, 2019, 11:14:08 am »
You can disconnect the top side of the INTENSITY pot to increase signal into the PI. Some people like to replace the INT pot with s pot with pull switch to use as a gain boost.
« Reply #4 on: July 21, 2019, 11:33:17 am »
"more preamp volume into the PA of a basic 2 channel non-reverb deluxe Ab763 build."   Some ideas:
* Double value of Power Tube Grid Leak Resistors (verify fixed bias afterward)
* Increase Voltage to PI  (smaller B+ dropping R)
* Add bypass cap to tone recovery stage (if not there already)
* Use 220K plate resistors in one or more preamp stages.  Maybe increase K R accordingly.  Maybe increase supply voltage (smaller B+ dropping R), if larger plate R is/are used.
Offline Toxophilite
« Reply #5 on: July 21, 2019, 12:11:43 pm »
Hey thanks.
This is actually my stereo deluxe reverb. The echo channel is a plain AB763 deluxe circuit (no trem or reverb sorry for not specifying.) Otherwise it's basically the same as two similar preamps being fed into the same PI via 220k mixing resistors.
 I was keeping it simple for the question but didn't realize people might offer other solutions. I wish I could put the schematic up but I don't have at this location.
« Reply #6 on: July 21, 2019, 12:19:26 pm »
Hey thanks.
Seems you left out some very important information. I feel like I've just been led down a dead end rabbit hole! THX
Offline Tony Bones
  • Thread Killer
« Reply #7 on: July 21, 2019, 12:53:39 pm »
How are the output tubes biased? Sometimes just running them a little hotter will get them involved a little sooner.
Offline Toxophilite
« Reply #8 on: July 21, 2019, 01:18:39 pm »
I actually did apologize, I hope you didn't lose too much sleep over it. :icon_biggrin:
Seriously though this was meant to be a simple and specific question, I am away from my home and don't have access to the schematic however I really just wanted to know about the mixing resistors.
I have the information I wanted, thanks, regardless
Hey thanks.
« Reply #9 on: July 21, 2019, 04:56:54 pm »
Consider using a bit less nfb on the power amp.
