September 19, 2026, 12:46:51 pm
Hoffman Amps Forum image Author Topic: Negative Feedback pop  (Read 7315 times)
Offline dude
« on: August 15, 2019, 11:18:03 am »
I searched the pop when feedback is grounded out with an on/off switch. Not too much here except a suggestion is get a "make before break switch", don't know what that is...? And some that used the make before, switch said no help. Was hoping for a cap fix to ground but search here revels not too much info on a fix.
Any suggestions?
Offline vampwizzard
    • Walbertedwards.com
Re: Negative Feedback pop
« Reply #1 on: August 15, 2019, 11:31:23 am »
Id assume that the solution would be similar to the standby switch resistor mod from Rob? https://robrobinette.com/Generic_Tube_Amp_Mods.htm#Pop_Reduction
Is it also possible that youre removing the connection to ground when youre taking out the negative feedback circuit?
Offline Tony Bones
  • Thread Killer
« Reply #2 on: August 15, 2019, 12:08:07 pm »
I don't know exactly what circuit you're talking about; a schematic would help. But, there's usually no reason to ground any part of the NFB when you switch it out; just use a SPST switch to disconnect/connect it.
Seriously, we need a schematic of what you're trying to do.
Offline dude
« Reply #3 on: August 15, 2019, 12:56:06 pm »
No schematic needed, a simple on/off switch between the Neg. Feedback R and the OT tap. No ground is involved, my mistake. I did add a 5K Presence pot to this amp, wired like a Plexi and 100 other amps and of course with the feedback R cut out, no presence control.
Just a slight pop turning off the switch, Presence pot is not even scratchy. Adding a resistor like on Rob's site for Stdy by switch, I can't see that helping. Would screw with the Presence and FB.
« Reply #4 on: August 15, 2019, 01:38:45 pm »
I don't pay much attention to NFB stuff so I might be all washed up, but don't you just open the NFB loop instead of grounding it?
Offline dude
« Reply #5 on: August 15, 2019, 02:05:49 pm »
Yeah, Shooter that's what I did, read my last post. I was "out to lunch" saying I ground out the loop in first post, I didn't, ha. I probably wouldn't turn the switch while playing out anyway, my playing out days are over,  :laugh: . I'm just being a perfectionist, fixing what ain't broke, ha.
Just thought, a cap across the switch or whatever would stop the pop. I'm sure a lot of amp guys have or had this issue. I'll search around.
« Reply #6 on: August 15, 2019, 03:18:03 pm »
There are some amps out there that do actually ground the feedback signal to switch it off. Here's one that I'm very familiar with. No pops...
     http://sluckeyamps.com/november/november.pdf
« Reply #7 on: August 15, 2019, 06:43:16 pm »
Negative Feedback Pop!  Let's market our own soft dink to amp techs!
« Reply #8 on: August 15, 2019, 06:52:48 pm »
Already got one. Oh, wait a minute. Is that what you meant to say?   :think1:
« Reply #9 on: August 15, 2019, 06:58:37 pm »
Not the "Think" Emoji.  Rather, the "Bright Idea" Emoji.  :icon_biggrin:
« Reply #10 on: August 15, 2019, 07:17:03 pm »
I was focused on the "soft dink".   :icon_biggrin:
« Reply #11 on: August 15, 2019, 07:26:53 pm »
 :l2: :l2:
just thinkin bout mine  :icon_biggrin:
just add the soft dink icon, I still need the  :think1: one
« Reply #12 on: August 15, 2019, 07:35:40 pm »
Here ya go!
« Reply #13 on: August 15, 2019, 07:43:17 pm »
Never mind. Sometimes a quip just doesn't connect. That's OK. Ain't worth explainin'.
Offline dude
« Reply #14 on: August 16, 2019, 12:09:44 pm »
Feedback Pop...? Just give me a beer,  :icon_biggrin: .
Tried that November, FB switch on the ground, still the pop, 11.5 volts at the junction of feeback and PI. That voltage is there which ever way the switch is wired, hence the pop. Some feedback switches I've added have no pop, (cutting FB R or grounding out) some do, just like the presence pot is sometimes scratchy, sometimes not.
Answer: live with the "Feedback Pop" but I prefer beer.. :laugh:
« Reply #15 on: August 16, 2019, 12:42:22 pm »
It connected well, it's a good crop year  :laugh:
Offline dude
« Reply #16 on: August 16, 2019, 04:43:16 pm »
Crazy, I took the pilot light out and put the Presence pot there.  The light was right next to the PI so the wiring to Presence was less than an inch, ground too and guess what, no pop, when I turned on/off negative FB. Even with the switch on the back of the amp, taking the feedback R out, not ground.
I have no idea why, when Presence was on the back, I used shielded wire, still had the pop. Nice to have that Presence on the front, usually it's set and that's it but on this amp with the three channel mini toggle in the bright input, I'm constantly changing the Presence when I change channels.
Now back to those 6V6 Plexi's, have 8 Hammond AO43 chassis's. I'll have to make a few Nov's too.
Now time for a Feedback Pop, oh, I mean beer, it's Friday night.  :icon_biggrin:
