September 19, 2026, 07:27:24 am
Hoffman Amps Forum image Author Topic: Popping when switching channels  (Read 4515 times)
Offline Diverted
« on: August 19, 2019, 10:17:21 am »
Hi all,
I posted this question day before yesterday in a different thread (two channel Princeton Reverb) but it must have gotten lost in the shuffle so instead of re-posting the question there, thought I'd just pull it out. Seems like it could be something applicable to other amps with similar channel switches.
Anyway, as Sluckey and others predicted I am getting popping when switching channels. It's not terribly bad but is audible and I would like to eliminate it if possible. Any suggestions? Thank you!
Ted
Offline Leevi
    • Rikstone
Re: Popping when switching channels
« Reply #1 on: August 19, 2019, 10:48:49 am »
Try to connect 1M or bigger resistors across the switch I.e. one from green to red and anotherone from blue to red.
You don't need the first switch (left) just connect the input to both grids
/Leevi
« Last Edit: August 19, 2019, 10:52:20 am by Leevi »
Offline Diverted
« Reply #2 on: August 19, 2019, 10:53:09 am »
Thanks! will try it on the plate side of the switch.
« Reply #3 on: August 19, 2019, 02:34:39 pm »
Offline d95err
« Reply #4 on: August 19, 2019, 03:53:32 pm »
Since there is so little difference between the two input stages. Why not use just one input stage and switch between two different cathode resistor/capaciptor combinations? You'll save a triode to use for something else...
