September 18, 2026, 04:50:04 am
Hoffman Amps Forum image Author Topic: Standby Grounding Issue  (Read 8379 times)
Offline ululufut
« on: August 28, 2019, 04:38:40 pm »
I have a vexing issue made more so by that I solved the same issue earlier and now it's back, this time without a findable solution as of this time.
A 5E3-type circuit I'm working on is producing a low level 60 cycle hum on standby. Live the hum is louder, although in each instance it is not obtrusive. I would say that, on standby, the hum is what I would expect from the circuit when live, and the live hum is a little more than that.
I have checked the voltages on the V1-V2-V3-V4 plates on standby and they all seem normal - a trivial number of millivolts. Live, the values are all pretty high - I have bigger transformers in there. But they seem reasonable - in the low 200's on the preamp tubes and low 400's on the EL34's.
For the filter caps - on standby they're all running about 445mV. Is this normal?
The transformer/rectifier connections all seem legit - moreover the amp was quiet on standby earlier so this seems like an unlikely source.
One thing I'm unsure of, however, is that the rectifier (I'm using a plugin diode) pins 2 and 8 are at 327V on standby, and 423 when powered up. I frankly don't know what the values should be here.
Other ground connections:
Cathode bias 250Ω resistor - grounded
Input jacks -> potentiometers - grounded
PT high voltage center tap - grounded
PT shield wire (Allen TP40D) - grounded
PT 50V bias tap - grounded (should this be grounded or heat shrinked? It didn't cause an issue earlier)
Here's my standby switch wiring:
1. Rectifier pin 8 to Standby
2. Standby to positive end of first filter cap.
3. OT center tap to positive end of first filter cap.
One thing I just noticed is that the turret lug at the base of the + end of the first filter cap is a little loose in its footing. I don't imagine that makes a difference but I don't know exactly.
I seem to be running dry on solutions. What else can I check?
Re: Standby Grounding Issue
« Reply #1 on: August 28, 2019, 06:14:17 pm »
that indicates filaments, possibly jostled wires picking up hum, ground connections loose
did you roll in different tubes for testing?
Offline ululufut
« Reply #2 on: August 28, 2019, 06:21:59 pm »
Yep - swapped preamp tubes as well as a pair of output tubes.
« Reply #3 on: August 28, 2019, 07:15:36 pm »
BINGO! PT is probably damaged at this point.
« Reply #4 on: August 28, 2019, 07:28:59 pm »
It’s a bad idea to connect a 50V power source to 0V.
Try disconnecting it and you may be lucky.
What value mains fuse has the amp been fitted with?
Offline ululufut
« Reply #5 on: August 28, 2019, 07:48:16 pm »
Sluckey & pdf - I was just thinking "how could I have been such an idiot?", but it turns out I didn't have the 50V tap grounded after all. "So I have that going for me... which is nice". On the flip side, I still have a humming amp.
It was after multiple hours - unveiling several weak spots, nonetheless - that I came up with the 50V tap theory. I was just tired. Anyway, looking for the source of the whiff helped me clean up the wiring - still have a few days until I have to take it on vacation with me.
Offline silverfox
« Reply #6 on: August 28, 2019, 07:57:18 pm »
What grounding scheme did you use? Star; Buss?
silverfox.
« Reply #7 on: August 28, 2019, 07:59:59 pm »
Teach it some words. Start with something simple and repetitive...
Baby shark, doo doo doo doo doo doo
Baby shark!
Offline dude
« Reply #8 on: August 28, 2019, 08:17:54 pm »
No, no not baby sharks, my grandson wants baby sharks every time he visits. I can’t handle any more “Baby Sharks” can’t stop humming that tune, going crazy. I might have to learn that riff, what key is it in...?
« Reply #9 on: August 28, 2019, 10:12:09 pm »
Try the key of A shark...
             A#
Grandpa shark, doo doo doo doo doo doo
             D#
             A#
             F
Grandpa shark!    :icon_biggrin:
Offline ululufut
« Reply #10 on: August 29, 2019, 08:15:56 am »
I'm going with "Baby Snakes"
Offline ululufut
« Reply #11 on: August 29, 2019, 08:18:24 am »
Buss.
« Reply #12 on: August 29, 2019, 08:26:04 am »
Might be too ambitious for a 5E3.   :wink:
« Reply #13 on: August 29, 2019, 12:12:54 pm »
Just turned noon, into the Icehouse already?
« Reply #14 on: August 29, 2019, 01:19:38 pm »
 :laugh:
it's sunny n 75 here.........
retirement you only have 2 times sleep n whatever the hell else you want  :icon_biggrin:
Offline Tony Bones
  • Thread Killer
« Reply #15 on: August 29, 2019, 06:00:59 pm »
You need to allocate some of your time to planning ahead for the early bird special at the Cracker Barrel. Then there's doctors appointments....
« Reply #16 on: August 29, 2019, 06:28:51 pm »
Cracker Barrel.
:laugh:
I did that when I worked, stop #1
but now they're closed permanent Ecoli they can't kill  :icon_biggrin:
n I worked for Doc's for 33yrs, it's over-rated
« Reply #17 on: August 29, 2019, 08:09:57 pm »
Hey! You been reading my calendar?    :l2:
