September 14, 2026, 01:28:32 pm
Hoffman Amps Forum image Author Topic: 1482Esq  (Read 54683 times)
Re: 1482Esq
« Reply #150 on: April 01, 2020, 03:47:26 pm »
Two things...
The 1M resistor under the speed pot should be 100K.
A 12AU7 does not have enough gain to work in this circuit. Change to 12AX7, or, if you want to keep the low gain 12AU7 in the cathodyne position, change to a 12DW7 tube. That way you have a low gain triode for the cathodyne and a high gain triode for the oscillator.
Re: 1482Esq
« Reply #151 on: April 01, 2020, 04:29:22 pm »
I can just swap the AX from V2 into V3 and make V2 an AU for now, slipping the decimal also  :laugh:
thanks
dave
Re: 1482Esq
« Reply #152 on: April 01, 2020, 05:06:40 pm »
alive, still waiting for the posthuman to do Her part, email says by Friday
Re: 1482Esq
« Reply #153 on: April 02, 2020, 04:10:51 am »
So you not gonna perform a photocell-otomy on that Fender roach? Real easy to put it back together if it doesn't act like you want. That photocell ain't picky about where it's light comes from. Marry it to your red LED while waiting for the postman. There was another forum member that successfully did this for the TON.
Re: 1482Esq
« Reply #154 on: April 02, 2020, 07:46:02 am »
:laugh:
I'm assuming it's fine, I just used it wrong.
gonna re-do DV and AC bench checks since I got 10hrs on the tubes and I noted Bias drifted up.
Something I should know but.....
Since I'm self biased PP A1, am I "ok" running close/over to max diss, instead of the "60%" fixed guideline  :dontknow:
Re: 1482Esq
« Reply #155 on: April 02, 2020, 10:51:04 am »
Yes, most all cat biased amps run 90-110%.
Re: 1482Esq
« Reply #156 on: April 02, 2020, 11:35:07 am »
thanks, I was wobbly on PP  :icon_biggrin:
It's too nice a day to be inside and Pam's home wounded from moving the large among us
so the amp might get a couple days rest  :icon_biggrin:
Re: 1482Esq
« Reply #157 on: April 02, 2020, 06:23:59 pm »
I'm such an addict  :think1:
9 gator-clips, 2 ecaps and 2 meters, don't get any better  :icon_biggrin:
Thanks DL, I put 100uf at tap A and another at tap D, tamed the ripple so I'm happy.  I was never "out of spec", but the "swing" was end-to-end of my "spec"
now the fluke gets bored
~ 7.8mV AC at tap D, ~ 2V at tap A.
so caps on order, threw in 2 1X/10X reasonable priced scope probes since I only have 1 left +HV probe
the snow blower did make it to it's summer home  :laugh:
Re: 1482Esq
« Reply #158 on: April 03, 2020, 01:07:07 am »
I did that, and now it snows every day.
Enough for kids to make snowmen.
Mostly melts by noon.
Re: 1482Esq
« Reply #159 on: April 03, 2020, 08:55:04 am »
ya, had that last week, last gasp winter, Every spring indicator is here now sans swallows and hummingbirds, but they always sleep in  :laugh:
Re: 1482Esq
« Reply #160 on: April 04, 2020, 05:27:18 pm »
found 10minutes and put in the roach, results not good.  well marked so got the LED in correct.  here's a scope shot from top of LED, I was on the 20mV scale 1X and it's to low for the digital to guess at values.  Freq setting about where I expected.
since I got way more IC opto's than i'll ever use now, might BB up one on a battery n experiment but got life getting in the way for the next day or so.
Re: 1482Esq
« Reply #161 on: April 05, 2020, 08:50:13 am »
Use your 87V to check the AC voltage and frequency at the plate of the oscillator tube. First set the freq to 5Hz with the speed pot. Then check the ACrms voltage. Should be about 100VACrms. What have you?
Re: 1482Esq
« Reply #162 on: April 05, 2020, 09:12:31 am »
with fluke;
5.38hz (range ~3hz - 17hz)
Min 70vac
max 76 vac
avg 73vac
Re: 1482Esq
« Reply #163 on: April 05, 2020, 09:33:51 am »
And what is the dc voltage on the cathode of the tube?
Re: 1482Esq
« Reply #164 on: April 05, 2020, 09:35:54 am »
with roach, 1.46, when I had the redled, was 1.65
Re: 1482Esq
« Reply #165 on: April 05, 2020, 09:40:20 am »
Is your roach a VTL5C1?
One more check with the 87V... Disconnect the VTL5C1 from the INT pot. Measure resistance of the VTL5C1 dangling leg and chassis. It will be changing so set the speed pot to slow and use the MIN-MAX feature on the meter. What have you? Only interested in min/max numbers.
Re: 1482Esq
« Reply #166 on: April 05, 2020, 10:02:38 am »
Is your roach
yep, antique radio, NOS
max 2.7M (drifts UP, about 1once in 30 seconds by 10K or so, 1st Max was ~1.6M)
Min 72k
NOTE:
after ~ 8minutes, quit ranging and settled at 3.4M  Min stayed happy
« Last Edit: April 05, 2020, 10:11:36 am by shooter »
Re: 1482Esq
« Reply #167 on: April 05, 2020, 10:40:32 am »
Everything appears to be working. Now use a gator clip and connect the dangling leg of the VTL5C1 DIRECTLY to the circuit as indicated in this pic (not using the INT pot yet. You do have the two caps in place, right? Report back.
DO NOT CONNECT THE VTL5C1 TO ANY DC VOLTAGE!!!
If you don't get a strong trem effect then move the gator clip to V2 pin 2. Report back.
Re: 1482Esq
« Reply #168 on: April 05, 2020, 11:05:44 am »
held my hand all the way!  :laugh:
trem is strong, freq varies, swamp works.
probably bad shielded cable.  I'm out for the afternoon mostly, thanks.
Nother oddity NFB, was playing with it earlier, with the 39k engaged, I get a "cleaner, small gain boost" and sounds nice, when the 680 ohm engaged, screams
Re: 1482Esq
« Reply #169 on: April 05, 2020, 11:20:15 am »
OK. Now connect the VTL5C1 back to the wiper of the INT pot and connect the top of the INT pot to the circuit. Ground the bottom of the INT pot. What have you?
Re: 1482Esq
« Reply #170 on: April 05, 2020, 05:29:34 pm »
I'm beginning to think this amp is cursed
  :w2:
ok, here's my testing;
Wired per snippit;
No guitar sound
.4ohm from injection point to ground
Verified cable and pot good disconnected from circuit
Wired back up, same  .4ohm
Installed new pot, same
Resistor side of opto infinity to ground
Original pot 100kRa
2nd pot 500kL
Disconnected, guitar sounds
Opto jumpered as before works as before
Oddity;
No power, in circuit, pot disconnected from incretion point, connected to opto and ground;
pot read 0-120k – 0, out of circuit 0 – 500k
who needs an int pot  :laugh:
Re: 1482Esq
« Reply #171 on: April 05, 2020, 06:22:12 pm »
3rd pot's a charm!
first 2 were new, Cmade, test good outta circuit.
I have a 1M L beat up radioshack, works fine in circuit, but only from ~.9M to 1M
anything less and trem either quits, or guitar just overwhelms it.
It's time for some AMERICAN HOMEGROWN POTentiometer    :icon_biggrin:
Re: 1482Esq
« Reply #172 on: April 05, 2020, 07:28:50 pm »
did a AC trace for some wonky, but not bad sounds, found problem, not resolving tonight  :icon_biggrin:
big wave is plate of cathodyne, small input.
Big R's in morning  :laugh:
Re: 1482Esq
« Reply #173 on: April 06, 2020, 07:35:39 am »
Waiting for the Sun I went back and looked;
when I went to AX in the PI I had girlfriend looking wave, now, gramma looking.
The only changes;
1k under cathode of PI, and cut input cap feeding PI from .01uF to .005uF
anyone got a sense about that before I try n "fix" something that wasn't broke  :dontknow:
Re: 1482Esq
« Reply #174 on: April 06, 2020, 07:47:36 am »
What's the status of the tremolo?
Re: 1482Esq
« Reply #175 on: April 06, 2020, 08:58:49 am »
I have a 1M L beat up radioshack, works fine in circuit, but only from ~.9M to 1M anything less and trem either quits, or guitar just overwhelms it.
This "tells me"  any "loading" messes with signal/trem, passed my paygrade to get if it's an impedance thing, insertion location,.......
It does work as expected, just over a very short range
(the resistance I'm quoting is from insertion to ground, measured no power after I played and found the pots range)
Re: 1482Esq
« Reply #176 on: April 06, 2020, 10:10:59 am »
clarified gibberish;
pots 1 & 2 and shielded wire removed, verified outside circuit to be good.  There had to be a fail somewhere that I missed.
Pot 3 1M l measures consistent .98M to ground at insertion point.
Pot3 wiper to ground;
at .98M, strong trem, strong guitar
at .91M, no trem (sound), strong guitar
Re: 1482Esq
« Reply #177 on: April 06, 2020, 10:28:41 am »
Disconnect the INT pot. Use a gator clip to connect a 47K from ground to the insertion point. Do you still have enough guitar signal to be useful? If so, use a 50K pot.
Re: 1482Esq
« Reply #178 on: April 06, 2020, 12:13:02 pm »
that's where I was heading next.
Gave up on "why", added 10_edit_K Gstoppers to the PA tubes, added a 470k Gstopper into PI.  (Thanks DL:)
signal path is as good as it's gonna get.  The gain pots need tweaking since range for "good signal" 0 - 5, past 5 things distort up in a not so good sound.  Difference at speaker power wise is minimal
pic 1 after Gstoppers
Pic 2 max clean PI in, Speaker out
pic 3 Max usable, same points as pic 2
Re: 1482Esq
« Reply #179 on: April 06, 2020, 03:07:14 pm »
here's the data;
Baseline, nothing at insertion point to ground, (all #'s Vacrms)
in 38.6 out 39
470K to ground
38.5  39
100K to ground
38.3 38.3  (starting to "load" signal, slight distortion top n bottom lobes)
56k to ground
36.8  35.4 (heavier "loading" on lobes)
Re: 1482Esq
« Reply #180 on: April 06, 2020, 03:31:33 pm »
OK. Leave the 56K connected and also connect the opto dangling leg to the insertion point. This is the same as having a 50K int pot set to max. How is the trem effect? Put your scope down and plug in a guitar. I want to know what your ears think.
Re: 1482Esq
« Reply #181 on: April 06, 2020, 03:37:55 pm »
was doing this when you called;  :laugh:
hunted down a 100k, verified, installed, and I got 1K to ground at insertion  :cussing:
roach reads 1K to ground  :cussing:
powered up, roach danced the fluke, but only "around" 1K  :cussing:
Never been much of a quitter, but this might be a good time to practice  :icon_biggrin:
Re: 1482Esq
« Reply #182 on: April 06, 2020, 04:10:54 pm »
How the hell do you put a 100K between the insertion point that I suggested and ground and then measure 1K. Not likely in my world.
I ask for a 47K to ground but you show me a bunch of data using various resistors, one being 56K. OK, that's pretty close to 47K. Then I ask for you to leave the 56K in and also connect the opto to the insertion point. But you connect a 100K!!! We sure ain't communicating.
Show me some pics of this amp! No scope traces please.
Re: 1482Esq
« Reply #183 on: April 06, 2020, 05:38:49 pm »
we're on the same page,
I wanted to know what NO trem value was, 1st measure.
Since I had 1M pot that worked, I started there  and went backward to 47K. (56k, called that one close and quit looking)
The problem is the roach resistance keeps changing.
last night I played, it trem'd like I expected with the 1M pot.
The roach ohmed infinite 2 or 3 times during testing
The roach ohmed 1K 2 times during testing
EVERY time I ohmed the roach the "wiper" wire was disconnected, amp off.
I have 2 NEW roaches and 3 NEW pots on order.
we can both use the break while parts are coming  :laugh:
If the roach is supposed to be 1k to ground, or it's irrelevant then I'm game for whatever.
Re: 1482Esq
« Reply #184 on: April 06, 2020, 07:33:31 pm »
You've proven that the TON circuit is functioning. Now all you gotta do is experiment to find the right interface. Just keep experimenting, you'll get it.
Here's a variation of the interface that a guy over on TAG used. His trem sounds phenomenal.
Re: 1482Esq
« Reply #185 on: April 07, 2020, 08:23:30 am »
:laugh:
once I learned to solder, I learnt 60hz was audible and I had a power cord and speaker  :icon_biggrin:
Re: 1482Esq
« Reply #186 on: April 10, 2020, 07:49:53 am »
Any progress?
Re: 1482Esq
« Reply #187 on: April 10, 2020, 10:17:52 am »
 :laugh:
No parts yet, but I'm playing better.
This thing is really a nice one for noodling on, fixed the NFB, just subtle differences to me, same with the tone knobs, but I'm not a knob fiddler.
The Gov won't let me n my brother fish in the same boat, so getting parts past the check points might be iffy  :icon_biggrin:
Re: 1482Esq
« Reply #188 on: April 10, 2020, 12:55:02 pm »
The Gov won't let me n my brother fish in the same boat...
i thought alcohol kills corona?? if that's true, i don't see how that's an issue as long as you're getting seriously hammered when you're fishing. did i miss something?
Re: 1482Esq
« Reply #189 on: April 10, 2020, 01:10:40 pm »
:l2:
You'll need ALOT to understand this edict!
"No more than 2 related persons per boat, same address"
I don't live with my brother so I get thrown overboard  :icon_biggrin:
Re: 1482Esq
« Reply #190 on: April 11, 2020, 05:33:13 pm »
new roach in, trem works as designed, but INT pot (100k) is only good from 7-10.
so gonna re-wire like the bandmaster final with the 10k cathode R and FS toggling the LED, and a 50K int and evaluate.
but I smoked my brakes NOT smoking a dog, so 2 blown lines and a complete bleed-down and it's back to early march temps  :cussing:
Re: 1482Esq
« Reply #191 on: April 13, 2020, 04:15:29 pm »
Buick on hold so I soldered up the Proper parts and it Trems well, good range, nice sounds for a hack wanna-be.  marking up the schematic, callin it DONE  :m17
Offline Platefire
Re: 1482Esq
« Reply #192 on: April 19, 2020, 10:01:21 am »
Whew! Ya'll was wearing me out :think1: Glad that's solved. I know what it feels like to want to give up on something but it's quite a victory once you get there. Ya Haw!!! :happy1:
On the right track now<><
Re: 1482Esq
« Reply #193 on: April 19, 2020, 10:11:06 am »
I'm already washed up, worn out, but I can still crawl  :laugh:
Re: 1482Esq
« Reply #194 on: April 19, 2020, 10:25:28 am »
I have a bottle of corona dope. Unfortunately it dried up several years ago.    :cry:
Re: 1482Esq
« Reply #195 on: April 19, 2020, 10:33:33 am »
 :laugh:
was cleaning up random junk in the barn, found a jar of instant coffee from the '90s, paused while I though, hmm If the world melts....  Pitched it.
Found a random baggie, probably the same time-frame, laughed since I can buy that as  essential product  :think1:
Re: 1482Esq
« Reply #196 on: April 19, 2020, 05:56:46 pm »
Just the solvent/spirit. Try a cocktail like this:
Toluene 108-88-3 70.0 %
Ethyl Alcohol Denatured 64-17-5 10.0 %
2-Butanone (MEK) 78-93-3 5.0 %
Methyl Isobutyl Ketone 108-10-1 5.0 %
Re: 1482Esq
« Reply #197 on: April 19, 2020, 06:05:35 pm »
ok, pleading ignorance, I had lots of corona balls in my equipment, but never cleaned with corona dope, just alcohol  :dontknow:
Re: 1482Esq
« Reply #198 on: April 19, 2020, 08:00:04 pm »
Silly you. Corona dope ain't for cleaning.  :icon_biggrin:
Re: 1482Esq
« Reply #199 on: April 20, 2020, 07:26:27 am »
ok, sent the ducks, they got confused!
guessing it's the "finger nail polish" for coating wires, not the dielectric grease I put on the anode/cathode of X-ray tubes before seating them?  that was pure HiVolt silicon
didn't even bother with guitar cleaning product link
