September 17, 2026, 12:20:07 am
Hoffman Amps Forum image Author Topic: Minimum gr1 resistance  (Read 4996 times)
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
« on: December 15, 2019, 01:17:37 pm »
Hi !
  • Over a year ago I designed and built a single 5881 guitar amplifier which appeared to be very reliable. I used it day after day from one to 4 hours every day. Last night as my girlfriend was out with her friends ( that's what she told me...but  'till now she's always been as reliable as this particular amplifier hey hey hey ..). I was saying as she was out, it came to my mind to draw down the schematics of this wonderful amp since my blisters were too painful to play anymore and the 3 tv channels were annoying. I opened up the amplifier carefully on the kitchen table, looked for.my Fluke and my chinese no brand cap meter and started my work. My drawing was good and all the values were logical but one: the power tube grid leak resistor was measuring 3.5kohm. I was expecting to find 220k to 470kohm. Surprisingly this amp is my best ever. Obviously I had not measured the resistor B4 soldering it in it s place when I built this amp.
  • QUESTION: Is there a min grid leak value not to exceed ad what could be a possible issue using such a low value g1 resistor ? ( i m not talking about grid stopper here don t get me wrong). The data sheet of the 5881 shows a max of 500kohm.
  • THANKS.
P.S.: call me Alvin.
Re: Minimum gr1 resistance
« Reply #1 on: December 15, 2019, 01:58:26 pm »
I don't think the 5881 cares what size grid leak you use, as long as you don't exceed the maximum value. But that 3.5K sure puts a heavy load on the plate of the preceding tube. I would replace with a more appropriate value.
  • MAKE LOVE NOT WAR
« Reply #2 on: December 15, 2019, 03:00:05 pm »
Heavy load on the plate or not, I will keep this out of the blue value resistor if  a " more appropriate" one changes the amp tone. I will always regret to have modded a beautifully sounding amplifier ' cause many voltages weren't standard and 6V6' s lighjtly redplating.
But thanks for the info. I ll do the swap and see what happen. MAYBE AN EVEN BETTER TONE !
COLAS
« Reply #3 on: December 15, 2019, 04:42:45 pm »
Ciao Colas
When you measured the 3.5K, the resistor was disconnected from the circuit (at least at one side) or not ?
May be there is a resistance in parallel on the circit that altered your measure ?
  • MAKE LOVE NOT WAR
« Reply #4 on: December 15, 2019, 05:27:39 pm »
Ciao Kagli,  sure it was !
« Reply #5 on: December 15, 2019, 05:40:27 pm »
Ciao Colas
sure it was !
replay to the first or second question ??  :icon_biggrin:
  • MAKE LOVE NOT WAR
« Reply #6 on: December 15, 2019, 09:31:42 pm »
Sorry body it was the reply to the first question .
The resistor was disconnected. Anyway, it didn t matter, connected or not , same reading. No other resistor in the path.
Ciao fratello !
« Reply #7 on: December 15, 2019, 11:50:50 pm »
Have a nice day  :icon_biggrin:
