September 08, 2026, 01:12:51 pm
Hoffman Amps Forum image Author Topic: Looking for Rickenbacker M11 schematic using 12Ax7's in the preamp  (Read 8979 times)
Offline davohilts
I'm looking for a rickenbacker M11 schematic for the model that has 4 inputs and uses 12AX7 preamp tubes, can't find it anywhere on the web so thought I'd check in here, thanks for any help!
 Note: the common one I've come across has octal tubes in the preamp and 3 inputs!
« Last Edit: January 05, 2020, 08:09:54 pm by davohilts »
Re: Looking for Rickenbacker M11 schematic using 12Ax7's in the preamp
« Reply #1 on: January 05, 2020, 09:02:19 pm »
That pic screams homemade to me.
Offline K Teacher
« Reply #2 on: March 31, 2021, 10:01:37 am »
Hi,
I also have been looking for the Rickenbacker M-11 using 12AX7 in V1 position and 12AU7 (?) in V2 -- PI.
My understanding, after studying several pics on the web is as follows:
a)   M-11/ 3-Inputs w/ 12AX7 preamp:
This circuit uses a paraphase-splitter and its circuit is similar to the Lectrolab R500, which can be used as reference. The Lectrolab R500, uses 12AY7 tubes but the circuit is practically the same.
Link:  https://el34world.com/charts/Schematics/files/Lectrolab/Lectrolab_r500.pdf
NOTE: careful, there are Lectrolab R500a, b and c, which are completely different circuits.
b)   M-11/ 4-Inputs w/ 12AX7 preamp:
This circuit uses 12AU7 phase-splitter inverter/ concertina (like the Rickenbacker M-16) and its circuit is similar to the Harmony 305a, which is the same as Harmony 306a minus tremolo circuit (V5 – 6SH7).
Link:  https://el34world.com/charts/Schematics/files/Harmony/Harmony_h306a.pdf
My understanding is that all of these three amps brands were built in California, so I wouldn’t be surprised if all of them were designed by the same person or copies of each other with small changes in the circuit.
Hope this helps…
« Last Edit: March 31, 2021, 06:06:42 pm by K Teacher »
