September 15, 2026, 11:19:27 am
Hoffman Amps Forum image Author Topic: Distorted output signal  (Read 3866 times)
Offline Leevi
    • Rikstone
« on: January 11, 2020, 02:27:12 am »
I'm working with a 5D2 based amp and wonder the distorted output signal.
https://el34world.com/charts/Schematics/files/Fender/Fender_princeton_5d2_schem.pdf
I made two measurements (see the pics) with same volume (clock 9) and tone (clock 7) settings.
The first measurement (clean) is done on power tube grid before 1.5K  grid stopper (added to the circuit).
The second measurement is done on the output with 8 Ohm load.
Plate voltage: 305V
Cathode voltage: 17.7V
OT: SE OT 5K/8 Ohm
/Leevi
Offline Leevi
    • Rikstone
Re: Distorted output signal
« Reply #1 on: January 11, 2020, 03:41:36 am »
Found an issue with measurement cables so the situation is not that bad as described.
Some kind of distortion is normal?
/Leevi
« Reply #2 on: January 11, 2020, 04:06:51 am »
yup, I believe that amp is played distorted way more than played clean.
