September 15, 2026, 03:41:30 pm
Hoffman Amps Forum image Author Topic: Mil spec inductor ... which preferable use ?  (Read 4146 times)
« on: February 18, 2020, 11:54:50 am »
A friend has just given me this inductor
I'm not very familiar with inductors, usually we see inductance value and current rating
This inductor say also 10 V 60 CY - 820 Ohms
Questions
if I interpret correctly 10 V is the max ripple that can be tamed, correct ?
with this spec (only 25 mA DC) is better to reserve the use on G2 of the power tubes ?
820 ohms seems a bit high value, is it ?
« Last Edit: February 18, 2020, 11:58:33 am by kagliostro »
Re: Mil spec inductor ... which preferable use ?
« Reply #1 on: February 18, 2020, 12:52:17 pm »
the pic indicates it's a 30 henry (30 HY).  That's ALOT of Henrys I believe
« Reply #2 on: February 18, 2020, 04:10:30 pm »
820 Ohms at 25mA is only about 20V of DC drop. No big deal on a >200V feed.
30H at 60Hz is a 10k reactance, *much* more than 820 ohms; so it is a "good choke".
« Reply #3 on: February 19, 2020, 06:33:16 am »
Thanks Shooter & PRR
