September 17, 2026, 05:16:29 am
Hoffman Amps Forum image Author Topic: Help my BDRI  (Read 22242 times)
Re: Help my BDRI
« Reply #50 on: September 24, 2020, 06:30:58 pm »
different seats at the same movie
ovals are AC, must have a signal in THAT matches schematic notes
rectangles are DC, no input required
TP3 2.015 VDC          TP6 2.005 VDC          TP9 0.0 VDC
tp3 is DC, my bad, 6 & 9 are AC(IF we're both using schematic in reply 15)
Re: Help my BDRI
« Reply #51 on: September 24, 2020, 06:37:11 pm »
let's stay easy for now
do you hear relays clicking when you switch, does the led lite/nolite??
Offline Cramer1
Re: Help my BDRI
« Reply #53 on: September 24, 2020, 06:47:19 pm »
TP9 = 0
so find V2A and figure out what PW2 is, cable?  tube socket? .......
Offline Cramer1
Re: Help my BDRI
« Reply #54 on: September 24, 2020, 09:37:38 pm »
Ok so I can hear clicking when I use the foot switch, the red light comes on with channel select, and if I crank reverb I can hear it also, but at the same low volume.
Offline Cramer1
Re: Help my BDRI
« Reply #55 on: September 24, 2020, 09:44:48 pm »
TP9 = 0
PW2A and B are the Ribbon cable connections going from the main board to the tube board for V2. So P2 would be the ribbon cable? TP9 is on the main board side of that ribbon.
« Last Edit: September 24, 2020, 11:08:49 pm by Cramer1 »
Re: Help my BDRI
« Reply #56 on: September 25, 2020, 07:30:43 am »
so TP9 on main board>cable>tube socket ?
pull V2, ohm from socket pin 3,(probe where tube pin 3 was), to chassis ground
Offline Cramer1
Re: Help my BDRI
« Reply #57 on: September 25, 2020, 10:42:13 am »
I will try that. If pin 3’s socket to ground is good, could I swap V2 and V3, then run preamp out and if I get sound then, assume that V2 is bad?
Re: Help my BDRI
« Reply #58 on: September 25, 2020, 12:27:01 pm »
 :laugh:
it's a PCB amp, IF I make ANY assumptions, it's a poorly constructed cable/solder/foil/socket, probably one of that last things I'd assume is a preamp tube
Offline Cramer1
Re: Help my BDRI
« Reply #59 on: September 25, 2020, 04:47:31 pm »
So I haven’t gotten my meter back out, but I did swap tubes 2 and 3 and now my preamp out works.....
Re: Help my BDRI
« Reply #60 on: September 25, 2020, 04:54:25 pm »
then you should have a working amp since the PA checked out yesterday, you still have bad doggy solder connection, or possibly sloppy socket pins
Re: Help my BDRI
« Reply #61 on: September 25, 2020, 07:45:44 pm »
Maybe run the amp for an hour or two with 2 x meters clipped on the 16V dual rail PS. Look for changes in rail voltage if the channels start switching/reverb cuts in and out
If you shine a torch through the board its easier to see where the heat affects other parts - here's a BD I fixed a while back (Charring is from before I replaced the resistors) note the zener 'looks' fine except for heat burn around the trace pads which only visually showed up with the torch test
« Last Edit: September 25, 2020, 07:50:29 pm by tubeswell »
Offline Cramer1
Re: Help my BDRI
« Reply #62 on: September 27, 2020, 09:36:20 pm »
Pin 3 to TP9 rings out. TP9 also has 2 VDC with the tube swap.
