September 14, 2026, 03:26:20 pm
Hoffman Amps Forum image Author Topic: Les Paul Jr. PT and rectifier question  (Read 6437 times)
Offline yorgle
« on: March 24, 2020, 11:00:19 am »
I'd like to use a vintage PT I have lying about as part of a Les Paul Jr. build using a 6x5GT rectifier tube instead of a 5y3 (my PT lacks 5v filament wires).  My wall voltage at 122.5 and I'm getting 350-0350 on the secondaries/ 7.2 on the 6.3 filament leads.  The max plate voltage according to the 6x5 datasheet is 325 so it seems like I should add a bucking transformer on the primary side to pull things down a bit, unless there is room for extra voltage like with power tubes?
As an experiment, I stuck a 270 ohm 10W power resistor on one of the primary leads (about a 19v drop) which reduced the secondary high voltage to 300-0-300 and filament leads to 6.29 vac.  So I think a 12v bucking transformer would be just about right.  Any thoughts or suggestions are very much appreciated.
Offline Latole
Re: Les Paul Jr. PT and rectifier question
« Reply #1 on: March 25, 2020, 03:32:03 am »
With load, (as you see ) Power Transformer will do the job, no need bucking transformer.
PT with no load read alway higher voltages.
Why don't you use solid state rectifier diodes ?
Offline yorgle
« Reply #2 on: March 25, 2020, 11:20:09 am »
Thanks for the reminder about no-load voltages.  I guess I'll wait until I get some tubes wired in before getting too worried about the PT.
I like the glow of tubes.
« Reply #3 on: March 25, 2020, 11:45:12 am »
I suspect that 350-0-350 PT will give you a lot more B+ than that little amp wants. You'll probably need to increase the size of that 470Ω dropping resistor considerably.
Offline Latole
« Reply #4 on: March 25, 2020, 12:42:37 pm »
b
Why not  :laugh:
Offline yorgle
« Reply #5 on: March 25, 2020, 08:03:50 pm »
Yikes!  Just tested it with a SS rectifier and measured 640vdc!  Remember that scene in Jaws when the sheriff first sees the shark, stumbles into the cabin and says, “you’re gunna need a bigger boat.”   I may have to rethink this idea.
Edit:   It occurred to me that those square SS rectifiers are full wave bridge.  So that’s twice the voltage the 6x5 will output, right?
« Last Edit: March 25, 2020, 08:32:10 pm by yorgle »
« Reply #6 on: March 25, 2020, 11:26:16 pm »
Without a capacitor??
350-0-350 (700VAC) rectified onto a cap is 1.414X or 980 Volts DC.
700VAC rectified withOUT a cap is 0.9X or 630VDC (all ripple).
Offline yorgle
« Reply #7 on: March 26, 2020, 07:32:44 am »
Correct, no cap.
« Reply #8 on: March 26, 2020, 08:24:39 am »
Correct. All the numbers PRR posted are 2X the voltages you would have with a conventional two diode rectifier.
Offline yorgle
« Reply #9 on: March 26, 2020, 08:57:39 pm »
Plugged in my shiny new 6x5 tube tonight and thankfully nothing smokes, but I do indeed have 490vdc at the first filter cap and only a volt or so less at the second cap.  Of course, without the other tubes installed, these are still no-load values.  Tomorrow I’ll plug in a 6v6 and the other tubes and see where things stand.
« Reply #10 on: March 26, 2020, 10:18:03 pm »
....I do indeed have 490vdc ... still no-load values. ....
Oddly, 490V is just what the 6X5 sheet predicts no-load. Even with one or two 6V6 to load it, these are high voltages. Maybe this vintage PT is from something big?
Offline yorgle
« Reply #11 on: March 29, 2020, 11:41:08 pm »
Tubes are in and the amp sounds great up to about 70% volume, then it starts to whistle like a steam engine, so I’ve got some troubleshooting to do. Hopefully it’s just a bad preamp tube.  I made two deviations from the Gibson schematic (added a trem o nator tube and used only 2 (not 3) filter caps, but I don’t think either of these changes are causing the whistle.  Here are some voltage readings I took after 30 minutes of playing:
V1 (6sj7):  plate 150, screen 20, cathode grounded
V2 (6v6):  plate 318, screen 273, cathode 16
At 6x5 output: 372
At 1st filter cap (after 470 resistor): 355
At 2nd filter cap (after 22K resistor): 273
None of the schematics I’ve found here or elsewhere on the web include voltages, but these numbers seem reasonable for this circuit.  Anyone see anything out of the ordinary?
« Reply #12 on: March 30, 2020, 01:14:27 am »
https://www.ampbooks.com/mobile/classic-circuits/gibson-ga-5/  ?
Offline yorgle
« Reply #13 on: March 30, 2020, 07:18:47 am »
Wow, thanks for that link, PRR.  That’s exactly what I need.
