September 14, 2026, 09:18:39 pm
Hoffman Amps Forum image Author Topic: Rotary switch for tone  (Read 9486 times)
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
« on: March 27, 2020, 08:39:56 am »
In my last build I would like to hook up a rotary
 switch to act as a tone pot. It is a 6 position switch. I would leave the 6th one unconnected to have access to the original tone  of the amp.
What would be the best way to achieve that ?
Thanx
Colas
P.S.: call me Alvin.
Re: Rotary switch for tone
« Reply #1 on: March 27, 2020, 09:03:26 am »
Without seeing a schematic it's hard to understand exactly what you want. But, take a look at page 2 of this pdf. Might give you some ideas...
     http://sluckeyamps.com/VAC15/Vox_AC15.pdf
« Reply #2 on: March 27, 2020, 09:28:40 am »
There is also a different approach, option b instead of option a (Pot instead of Rotary Switch)
« Last Edit: March 27, 2020, 09:34:01 am by kagliostro »
  • MAKE LOVE NOT WAR
« Reply #3 on: March 27, 2020, 10:46:42 am »
Very interesting indeed.  No signal is sent to gnd in the vox nor in Kagliostro circuits.Now would this mod be more effective early in the circuit rather than late ? I have an idea in mind: since that rotary switch  is stereo, placing it between the PI and the output tubes would improve or disminuish it s effectiveness ? The schem I don't have, but the preamp section is copied from the Marshall 2204 model, without the tone stack. It is my second 2204 since january. The first one is a bit less bright and more pleasant tonically, though the trannies are the same ( but the power tranny on this particular one which is a toroidal type from Avel Lindberg but with same voltages) this is why I d like to add a tone switch to adjust the brightness. I removed the 1000p cap accross the volume pot to give it a try but it changed the overall tone , though less bright. I put it back in place after. Same with the 470k bypass cap (470p).
Thanx buddies.
Colas
« Reply #4 on: March 27, 2020, 11:14:05 am »
The circuits below provide varying degrees of bass cut; sounds like  your goal is variable treble cut?
« Reply #5 on: March 27, 2020, 11:17:50 am »
instead of PI to PA, might be better as part of your NFB, like a rotary presence control   :dontknow:
  • MAKE LOVE NOT WAR
« Reply #6 on: March 27, 2020, 11:18:33 am »
Yes, treble cut
  • MAKE LOVE NOT WAR
« Reply #7 on: March 27, 2020, 11:20:34 am »
Shooter  good idea, ( if there was a NFB  :icon_biggrin: )
« Reply #8 on: March 27, 2020, 11:38:27 am »
You can implement one NFB with values that can affect tone and not the general function of the amp
(I think  :icon_biggrin: )
p.s.: .... Treble Cut ......  :think1:  ......
EDIT: I remembered !
« Last Edit: March 27, 2020, 11:49:07 am by kagliostro »
Offline nihonlabtiger
« Reply #9 on: March 27, 2020, 11:49:48 am »
when I finally get to the point of building my own amp, I'm thinking of doing something similar with a pushbutton and rotary control.
Check out the schematic for the Selmer Zodiac tone control.
« Reply #10 on: March 27, 2020, 11:57:25 am »
..... with a pushbutton and rotary control
Or Rotary Switch + Rotary Control
other Selmer with Rotary Control
« Reply #11 on: March 27, 2020, 12:46:22 pm »
just build this and be happy  :icon_biggrin:
« Reply #12 on: March 27, 2020, 01:11:40 pm »
Can't find it right now, but I could swear that Ted Weber's site had a schematic for a rotary SW for different tone caps, to match values for F, M & V tonestack values.
  • MAKE LOVE NOT WAR
« Reply #13 on: March 27, 2020, 01:19:50 pm »
ended up with the easiest one, 1m pot between the k and right after the first coupling cap. A bit more subtle that what I was expecting but it does the job right. Thanx Franco, you're my man ! :icon_biggrin:
« Reply #14 on: March 27, 2020, 03:19:59 pm »
De Nada  :icon_biggrin:
  • MAKE LOVE NOT WAR
« Reply #15 on: March 27, 2020, 05:30:14 pm »
Hey Shooter, I d sure be happy I am certain that EQ would be awesome , I might build it one of these days !
Thanx for sharing it
« Reply #16 on: March 27, 2020, 05:50:05 pm »
 :laugh:
I got it from Franco couple years back  :icon_biggrin:
I'm not good enough to pull it off, but I keep lookin  :laugh:
« Reply #17 on: March 31, 2020, 04:56:27 am »
Ciao Colas
I was talking with a friend of a different thing, and a council for you exit out
is a thing only to have a try, but may be you can be happy with it
instead of the 1M pot give a try to a 2.2M - 3M - 5M
reverse log, but you can try with a no reverse one and if happy, you can obtain the reverse log with the trick of the paralleled resistors, if you are not able to find a commercial one
http://www.geofex.com/article_folders/potsecrets/potscret.htm
