September 14, 2026, 07:29:05 am
Hoffman Amps Forum image Author Topic: Noise issue with 70 SR  (Read 10826 times)
Offline Mars-Hall
« on: March 29, 2020, 07:21:49 pm »
I have a strange noise issue with this amp.  The noise seems to be frequency related to an A note. Also is touch sensitive, in that picking lightly, the noise does not occur.  My first thought was bad speaker, when tested with another cab, noise persisted.  It's underlying noise, heard in the back ground.  The touch sensitivity led me to believe it was power section related.  I replaced all electrolytic caps, installed new power tubes and swapped the rectifier.  I tried a 5U4GB which diminished the noise to some degree.  The amp has been converted to bias adjust and removed the large resisters from pin 5 of the power tube sockets.  Chop stick test shows no sign of cold solder joints, I re-flowed all areas disturbed to be on the safe side. Last thing I replaced all preamp tubes with known good, to no avail.
« Last Edit: March 29, 2020, 08:17:46 pm by Mars-Hall »
“I love being alive and I will be the best man I possibly can. I will take love wherever I find it and offer it to everyone who will take it. Seek knowledge from those wiser and teach those who wish to learn from me.”  Duane Allman
Re: Noise issue with 70 SR
« Reply #1 on: March 30, 2020, 08:30:26 am »
What large resistors are you talking about?
Offline Mars-Hall
« Reply #2 on: March 30, 2020, 05:13:24 pm »
My apologies, it's a 2000pf cap to ground.  I'm gonna change the plate resistors next.  Hopefully that will cure it.
« Last Edit: March 30, 2020, 05:19:18 pm by Mars-Hall »
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
« Reply #3 on: March 30, 2020, 05:53:29 pm »
the power tubes have plate resistors ? 50 ohm or so ?
P.S.: call me Alvin.
« Reply #4 on: March 30, 2020, 06:15:57 pm »
Offline Mars-Hall
« Reply #5 on: March 30, 2020, 06:17:12 pm »
I was referring to the 100k resistors in the preamp section.
Offline Mars-Hall
« Reply #6 on: March 31, 2020, 05:04:07 pm »
Today I lifted the board to see if there was conductivity, noise persists.  Upon closer inspection, I found these plate resistors for V2 looking a little dark.  However, both read within tolerance.
« Reply #7 on: March 31, 2020, 06:26:58 pm »
noise persists
looks or tolerance don't have much to do with solving noise.  Unless this is a restoration and not repair, put Metal film 1W in the early gain stages.  If it's a resto, use a scope, find bad R, order NOS, lots  :icon_biggrin:
Offline Mars-Hall
« Reply #8 on: April 10, 2020, 03:29:43 pm »
I replaced all plate resistors and still have the noise issue.  Even though the pots don't make noise when rotated, I discovered a small amount of DC voltage at channel 1, treble and bass  pots. Also at channel 2, volume and treble pots.  Could these leaky caps cause this noise, as described?
« Reply #9 on: April 10, 2020, 03:50:48 pm »
less than 1 or greater than 2?
sometimes meters are deceptive at real low volts
« Reply #10 on: April 10, 2020, 03:54:51 pm »
sorry ment to say, yes, leaky caps can cause weird stuff since the "right hand" side DC usually goes to next stage grid and messes with it
Offline Mars-Hall
« Reply #11 on: April 10, 2020, 04:08:43 pm »
I'm reading between 3-4 mv.
« Reply #12 on: April 10, 2020, 04:20:03 pm »
That low and I'm looking for another noise source, 1vdc and up, I'm swapping caps
this still the noise?
Offline Mars-Hall
« Reply #13 on: April 10, 2020, 04:24:10 pm »
Now the noise is mostly lowest 2 octaves only.   I tried to upload a short video but the file is too big.  I even tried editing it down.
« Last Edit: April 10, 2020, 04:52:30 pm by Mars-Hall »
Offline Mars-Hall
« Reply #14 on: April 10, 2020, 04:33:59 pm »
Here is the noise example.
https://youtu.be/Hr00DG5JquY
« Reply #15 on: April 10, 2020, 05:59:19 pm »
sounds like a guitar payer noise way more than a tech noise.
sounded like when you don't play, it's quiet?
for fun roll a known good tube in V1, check
IF no effect, move to .......until the "last tube" before PI
Offline Mars-Hall
« Reply #16 on: April 10, 2020, 08:24:38 pm »
Already went down the tube road, more than once.  The noise is volume and touch sensitive, in that at lower the volume or lighter playing, no noise.   Not sure what you mean by, "guitar player noise more than tech noise".  Is that another way of saying, "loose nut behind the steering wheel". :l2: I've tried the amp through another SR cabinet. Brand new tubes in the power section, rectifier included, and swapped out each pre, one at a time.  Re-tensioned all tube sockets.  Also installed new 470 ohm resistors on the power tube sockets and all the plate resistors.  Replaced all electrolytic caps.  Been reading in the tube amp library, that's what brought me to the coupling caps. It seems the DC voltage at the pots is negligible. Also tried unscrewing and lifting the board, with a chop stick.
The only other oddball thing about this amp, has a very thin coated wire, only seen on a handful of amps, from this era.  Perhaps there's a bare spot somewhere touching to ground, that I haven't noticed.
« Reply #17 on: April 11, 2020, 10:32:45 am »
sharpen up your meter probes to a "pin point", jab them into the board at various places and look for conductance (ohms, low values).  old fender boards are like fenders on old Chevy's :)
or
put a distortion pedal up from and learn to love the Metal sound  :icon_biggrin:
Offline 66Strat
« Reply #18 on: April 11, 2020, 12:38:23 pm »
Those 2,000 pf shunt capacitors were implemented by Fender to prevent oscillation in the power amp. Try putting the shunt capacitors back in place.
Regards,
JT
Offline Mars-Hall
« Reply #19 on: April 12, 2020, 09:50:59 am »
Due to the sloppy wiring?   This amp has excessively long runs in places. Looks like a rats nest. However, those shunts were removed years ago, this noise is relatively new.
« Last Edit: April 12, 2020, 10:07:22 am by Mars-Hall »
Offline 66Strat
« Reply #20 on: April 12, 2020, 10:47:44 am »
Partly sloppy wiring. The other piece to the puzzle, that doesn't show in the blackface schematics, is the capacitance formed by the cloth backed wiring lying flat against the chassis. Listening to the clip that you posted, to me, it sounds like there is some oscillation going on somewhere in the circuit. The shunt capacitors, to me, seem like a likely cure as that was Fender's solution. Alternatively, you might try a 100 pf to 200 pf capacitor capacitor between the plates of the phase inverter. Oscillation in this area was a concern even with the blackface and tweed circuits.
Regards,
JT
Offline dude
« Reply #21 on: April 12, 2020, 11:58:44 am »
Raise your action and try, if too low action or a high fret, you'll get that slight buzz when you first strike a note.
Offline Mars-Hall
« Reply #22 on: April 13, 2020, 12:33:03 pm »
Ok, what are the big rectangular resistors, in this photo, intended purpose?  These are what I remember removing.  It was a long time ago...
« Last Edit: April 13, 2020, 12:39:11 pm by Mars-Hall »
« Reply #23 on: April 13, 2020, 12:42:25 pm »
Those are cathode resistors. They add a bit of cathode bias to the amp, also a convenient place to monitor when adjusting the bias.
Offline Mars-Hall
« Reply #24 on: April 13, 2020, 01:31:27 pm »
That makes sense, I have the 1 ohm 1 watt resistors there now.
« Last Edit: April 13, 2020, 01:44:52 pm by Mars-Hall »
Offline 66Strat
« Reply #25 on: April 13, 2020, 03:07:31 pm »
IMO, no harm, no foul in replacing the 150 ohm cathode resistors with the 1 ohm resistors. It will simplify the biasing process.
Regards,
JT
Offline 66Strat
« Reply #26 on: April 13, 2020, 03:11:38 pm »
I don't know why Fender added the cathode bias in addition to the fixed bias supply, but in addition to biasing the tubes, the resistors also introduced some degenerative feedback.
Regards,
JT
« Reply #27 on: April 13, 2020, 04:09:02 pm »
hmm, and caps makes a more stable PA  :dontknow:
fwiw;
I looked back at my repair notes for a '65 SR
came in biased at 23ma (-57) plate 470vdc for ~11W
I bumped it to 47ma (-47) plate ate 450 for ~ 18W per tube
This unit had neither the 150 ohm or 2000pF and rattled my teeth at 7  :laugh:
