August 29, 2026, 04:55:18 pm
Hoffman Amps Forum image Author Topic: Stout MV  (Read 6157 times)
Offline Rockranger
Stout MV
« on: April 27, 2020, 11:35:41 am »
Hey,
    Just wondering how some of you guys would put a master volume in the Hoffman stout https://el34world.com/Hoffman/files/Hoffman_Stout.pdf . I had a few ideas just wondering the best way to do it.
Re: Stout MV
« Reply #1 on: April 27, 2020, 11:48:08 am »
can't see the need myself, there's one on the guitar, one on the amp  :dontknow:
here's some ways
http://el34world.com/Forum/index.php?topic=3496.0
Re: Stout MV
« Reply #2 on: April 27, 2020, 11:48:20 am »
You "could" just replace R12 with a 500K pot.
I would try a switchable resistor across the OT secondary as a fixed/switched attenuator. Don't forget to switch speaker jacks to match the new load.
Maybe both moves if you cant leave the house right now. The resistor is easy to try without commitment. The pot takes a few more minutes.
Offline Rockranger
Re: Stout MV
« Reply #3 on: April 27, 2020, 12:00:43 pm »
Thanks guys
Offline Latole
Re: Stout MV
« Reply #4 on: April 27, 2020, 12:02:40 pm »
A " real" master volume is a complete different thing.
I use this one sometimes :
« Last Edit: April 27, 2020, 12:07:18 pm by Latole »
Re: Stout MV
« Reply #5 on: April 27, 2020, 12:20:13 pm »
I recommend this...
Re: Stout MV
« Reply #6 on: April 27, 2020, 01:35:35 pm »
YUP
and after 5 years reading of folks doing 'em and 70% not liking them or not "getting what they hoped for" I still don't see a purpose, build a low watt amp for low watt conditions, build a big amp for big amp conditions, be happy  :icon_biggrin:
Re: Stout MV
« Reply #7 on: April 27, 2020, 03:59:35 pm »
Give a try to this
Obviously you must use (instead of R21 - R22) a dual ganged 470K (or 500K) pot instead of the 250K pot of the schematic (and no fixed bias)
Here you can find indication to obtain a log pot from a linear one (if you don't find a dual ganged log pot)
http://www.geofex.com/article_folders/potsecrets/potscret.htm
elsewere you can give a try also using a linear one
« Last Edit: April 27, 2020, 04:06:48 pm by kagliostro »
Re: Stout MV
« Reply #8 on: April 27, 2020, 08:06:06 pm »
Or this. Take the "820r" resistor bigger and bigger to taste.
Typo: it either should be REVerse Audio taper, CW for "LOUD"; or Audio taper marked "Choke" and turned the other way. (Tack-in any handy pot and try at 10, 5 and 0.)
The other problem is that EL84 is SOOO sensitive that it is really hard to turn drive down enough to reduce the racket.
Re: Stout MV
« Reply #9 on: April 28, 2020, 06:15:11 am »
Egnater on the Rebel 20 uses both triks at the same time, Pot on PI cathode + PPIMV
https://el34world.com/charts/Schematics/files/Egnater/REBEL20sch_8-09_with_Values.pdf
