September 15, 2026, 07:55:44 am
Hoffman Amps Forum image Author Topic: What does this trimmer do ?  (Read 4404 times)
Offline Rustynuts
« on: May 14, 2020, 09:40:05 pm »
Hi, I'm a newbie here and this is my first post.  If been gradually leaning about tube amps and have a few.  I have 4x el34  stereo amp.  This came from a church that had an old organ running into it.  ( No, it wasn't a B3 ) it hadn't been used for decades.  I replaced the valves and caps and added some 1/4" sockets.   It works great.  Tons of power.   I noticed this trimmer inside, not sure what it does.  Can someone enlighten me ? It's connected to the two sides of the heater filament circuit.   The orange wire goes to ground.   If I move it the heater voltage does not change.
Re: What does this trimmer do ?
« Reply #1 on: May 14, 2020, 10:24:23 pm »
tapped resistor for filament hum reduction. adjust for minimum hum when idling with a speaker load, or with an oscilloscope, or AC voltmeter.
Offline vampwizzard
    • Walbertedwards.com
« Reply #2 on: May 14, 2020, 10:30:54 pm »
"Hum balance". Depending on the actual circuit there were a couple of ways they did this back in the day.
Offline nandrewjackson
« Reply #3 on: May 15, 2020, 03:40:03 am »
+1 for hum balance pot.
I like that amp ! 4 - EL34s !
