August 29, 2026, 04:58:12 pm
Hoffman Amps Forum image Author Topic: Short (9") , long decay reverb tank for fender blackface type reverb circuit  (Read 3823 times)
Offline Toxophilite
I'm trying to hunt down a short size (9") long decay reverb tank that could be used with a fender blackface AB763 type amp. It's for a stereo vibrochamp I built into a very small cab, that incorporates an Ampeg stereo echo twin type of transformer driven reverb (they use the same tanks as the fender black face circuits)
I've found this one. Are the impedances close enough? 10ohm in and 2575 out
https://www.tubesandmore.com/products/reverb-tank-accutronics-8ab3c1b-long-decay-3-spring
thanks!
Yeah - if your RT is wound for 8R secondary it should be fine
Offline Toxophilite
Cool It's on order. Thanks
Offline nandrewjackson
I have  the short, 3 spring, long decay tanks in 2 running builds. I think they sound great.
