September 16, 2026, 03:00:22 pm
Hoffman Amps Forum image Author Topic: Sears 40XL Chassis & Iron. D-Style build?  (Read 23244 times)
Re: Sears 40XL Chassis & Iron. D-Style build?
« Reply #50 on: July 26, 2020, 07:01:53 pm »
put a 100k across the Mid pot; gator clip each lead to outside pins on pot, making the pot ~50K
did it help or hinder?
« Reply #51 on: July 27, 2020, 04:55:33 am »
Now, the more important issue is the sound. The mid boost switch is a HUGE boost and it seems to affect how the Mid pot works too. With the switch out, the tone controls don't seem to do very much at all. And with the mid boost on and if I push the volume past 3 or so, the distortion sound is "ratty"
Hmmm??   The PAB (preamp boost) somewhat disables all the tone controls and is a HUGE boost.  The mid-boost is more subtle and doesn't disable the tone controls.
Look at the attached illustration. Is your PAB wired up the same way?
Without the PAB engaged and without the midboost engaged ................  how is the clean tone for you?  Is it to your liking?
What kind of tube do you have in V1?   Is it a 12AY7?   or  5751?   I find that I don't like 12AX7's in that V1 position.
Offline JustMike
« Reply #52 on: July 27, 2020, 03:24:34 pm »
Tubenit, Ive got it wired like your diagram. Some of the cap values are slightly different comparing to the dwg I built to. One difference I noted is on the mid pot. The cap is tied to one side of the pot as well as the wiper. Your latest diagram shows the cap tied to the wiper only. I believe current takes the path of least resistance so it shouldn't matter, right?
And I'm using a 5751 in V1.
Edit- So upon further reexamination, theres something screwy with the wiring of the 330k fx resistor. The layout and the schematic dont show the same thing here. Am I reading this right? The layout doesnt show the connection to the .22 cap.
« Last Edit: July 27, 2020, 05:27:30 pm by JustMike »
I'm learning...
« Reply #53 on: July 27, 2020, 05:53:56 pm »
Schematic is correct.  The 330k doesn't connect with the wiper on the FX send pot.  It connects with the non grounded side which is where the .22 cap is.
You still haven't stated how the clean tone is?  Do you like how the clean sounds
IF that's not right then the PAB and mid-boost aren't going to sound smooth.  I would not be happy with a HUGE and buzzy boost tone.
You can wire the mid pot to just wiper OR connect wiper and side.  Either is fine.
IF you have a 12AY7 handy, give it a try in V1.
Offline JustMike
« Reply #54 on: July 27, 2020, 06:35:38 pm »
A little more listening and with no switches engaged, when I pick gently with a low output strat, the sound is ok at low volume, but when the volume gets past 2 or so, or when I pick hard, the result is bad distortion.
 I dont have any lower output tubes.
I'm learning...
« Reply #55 on: July 27, 2020, 07:20:16 pm »
Something is definitely not right with the amp.  Ryan's amp has a super clean warm tone. Sort of a AB763 clean but (IMO) a warmer fuller tone.  No distortion at all.
I can't find a soundclip specifically of Ryan's amp?   However,  his amp was essentially modeled after the Tweed BluezMeister that I had with ONLY the clean channel  V1a & V1b going into the active FX and then into the LTPI (and NO V2 OD channel).
I did find a sound clip of my TBM with on board active FX loop where the first 30-40 seconds of the soundclip is just the clean channel.  Your amp should sound similar in a clean tone to the first 30-40 seconds to this clip (after the 40 sec, I engaged the OD):
https://soundclick.com/r/s74j51
I once had the OT wires backwards and instead the typical loud squeal, I got a bad distorted sound and some oscillation.  Any chance that could be the case here?   One way to check would be to disconnect the NFB.
« Last Edit: July 27, 2020, 07:39:57 pm by tubenit »
Offline JustMike
« Reply #56 on: July 28, 2020, 10:06:31 am »
 I was thinking I was lucky when I first fired it up and didn't hear the crossed OT squeal. I'll look into this this afternoon after work. Thanks again Tubenit.
I'm learning...
Offline JustMike
« Reply #57 on: July 28, 2020, 04:36:22 pm »
I disconnected the NFB and theres not much difference. I also plugged my strat into the fx return to bypass a bunch of stuff and surprisingly (to me anyway) when I turned the fx return all the way up, it distorts. I would think there wouldn't be enough signal to drive the pi & output tubes.
Tubenit- I listened to your recording and I would love to get this amp there.
I'm learning...
« Reply #58 on: July 28, 2020, 07:52:57 pm »
Two thoughts …………………..   I've never owned or played any amp at all where I dimed all the controls.  I don't drive my car with my foot all the way down on the gas.   My opinion is that amps are NOT made to have everything dimed especially when you have a goal of a clean tone.  Probably any of my current 3 amps will distort into an unpleasant tone IF I dimed everything.
I have certainly plugged into a FX return and enjoyed a very nice clean tone doing that.  I doubt I had the FX return or FX level above 5.  I've played my Larrivee acoustic thru the FX return and loved the clean tone it had.  I've done that with several of my amps and enjoyed a nice rich clean tone with my acoustic.  Same good results with each amp I tried.
So,  ……………  IF you did not have the FX return or FX level cranked way up and it still distorted.  Then I'd say something significant is wrong in the wiring, tubes or OT or speaker.
IF you have another amp that has an FX in it.  Try playing your preamp thru the power amp of the other amp.  In other words,  take your send FX jack and plug it into the return of the other amp.  IF that sound clean to you, then the problem is the FX return or power amp on.
Another thing you can do is remove the FX tube and jumper straight from V1b into the LTPI.  How does that sound?  IF it's sounding clean and good to you, then the problem is the FX wiring or tube.
You're trying to isolate where the problem is coming from.
I've built several Tweed BluezMeisters and then Ryan's amp.  All of them had a very similar nice clean tone and sounded much like the early part of that sound clip.
Something is obviously amiss and I'm confident that you can get this figured out.   :thumbsup:
Also check voltages,  recheck resistor values and check for continuity.  Carefully safely chopstick the solder joints and see if anything pops or crackles.
You might try a 12AY7 or 12AV7 in the FX.  You might try a 12AT7 or 5751 in the LTPI.
« Reply #59 on: July 29, 2020, 09:06:06 am »
+1
When I started building, the guitar guys always dimed them!! the good sounds, got ugly at 10!  So I started "designing" them to be dimed, voltage dividers, lower gain stages... now you can dime away  :icon_biggrin:
Offline JustMike
« Reply #60 on: July 30, 2020, 07:58:13 am »
I understand about "diming" amps, but I thought that plugging a very low output signal like a guitar into the fx return without any preamplification wouldn't be able to overdrive a power stage.
I'm learning...
« Reply #61 on: July 30, 2020, 09:38:38 am »
Think of your amp as a preamp, FX & LTPI and power tubes.  Isolate where the problem is with the suggestions in my previous post and give us an update, please.
And let us know if you've tried different known to be good tubes also.
« Reply #62 on: July 30, 2020, 10:22:37 am »
The FX ret. feeds a gain stage, the PI has gain, not gonna do the math, but I suspect 2 gain stages with a hot pickup might bend 6V6's
Offline JustMike
« Reply #63 on: August 01, 2020, 09:45:04 am »
 Tubenit, I tried your idea of isolating the pre and power sections using another amp. The preamp sounds fine and everything works as it should. When I tested the PA with a known good pre section, if I turn my fx return up past 2 or 3, there's the rattiness.
 Remember, the OT I'm using is from a Peavey 6L6 amp. Their schematic shows it has 2 and 4 ohm secondaries. I think I'm correct in my 8 ohm speaker should be OK using the 4 ohm secondary with 6v6's. I do have what I think is an original Blues Jr. OT-part # B-049969. Maybe this would be a better match?
And just for reference, here are my voltages;
PSU nodes;
A-387
B-373
C-323
D-314
E-304
v1-1-176
v1-6-272
v2-1-205
v2-6-314
v3-1-234
v3-6-236
V4-3-371
V4-4-369
V4-8-27
V5-3-377
V5-4-369
V5-8-27
I'm learning...
« Reply #64 on: August 01, 2020, 10:58:58 am »
Bypass the FX loop and let us know how it sounds, please?  IF it sounds OK, the problem is the wiring in the FX loop.
I note quite a bit of a difference with V1-1 and V1-6 plate voltages.  I'd recheck the values for the plates and cathodes on that.
And the FX V2-6 connects directly to B+ rail?  Is that correct?
What value do you have for the FX return pot?  Sometimes I don't use an FX return pot and instead have used either a 82k to ground or a 39k to ground.  I guess I'm saying it wouldn't surprise me if the FX return pot past 3 would possibly sound ratty.
I am understanding your statement to mean you have an FX send,  FX return and an FX level pot.  Is this correct?
I think you need to try bypassing the entire FX system and see if the preamp into the LTPI sounds good.
Offline JustMike
« Reply #65 on: August 01, 2020, 01:04:48 pm »
OK, I bypassed the fx ckt. No real difference. I also checked my values around V1, everything is as it should be. And I made a recording so you can hear the "ratty" sound. Enjoy.
https://soundcloud.com/mike-holtzinger-300757342/mikes-ryans-amp-test
Recording was made with the volume on 2-3.
I'm learning...
« Reply #66 on: August 01, 2020, 02:20:53 pm »
You're saying that V2 (both triodes) are out of the circuit in the sound clip.  And yes, that doesn't sound right at all with just V1 going straight into V3 (the LTPI). It should be a very clean tone.
I am presuming in the sound clip that the mid boost is not engaged, the PAB is not engaged and your volume is not higher then "5"  (12 noon)
OK, based on what you're saying …………………….
1)  The preamp tube V1 and V2a into another amp sounded just fine.
2)  And you're saying with V2a & V2b out of the circuit completely. Both triodes of the FX,  the problem still exists.
     (per sound clip demo)
3)  So that leaves   V3 (LTPI) and the power tubes and the OT as the potential problem.
so I would ……………………..
 - recheck all the component values from the LTPI on
 - try a different 12A_7 that is known to be good in the LTPI
 - try different power tubes that are known to be good
 - try a different speaker that is known to be good
 - try a guitar with single coils if you have one
 - recheck the wiring for the 15th time   (I say this because there are rare occasions that I miss something with multiple
   rechecking of my wiring)
IF none of those reveal the problem,  please post a photo of the inside of your amp chassis as currently wired.  I've never had a bad OT before but perhaps that's an issue if nothing else proves to be the culprit?
« Reply #67 on: August 01, 2020, 02:24:55 pm »
A bad OT could produce that sound. Best way to check an OT is substitution.
Offline JustMike
« Reply #68 on: August 06, 2020, 04:36:14 pm »
Ok, I think I found the problem. I ASSUMED the Peavey OT's primaries were red and blue with brown being the center tap. Through process of elimination, I've narrowed down the problem to the OT. So with an ihm meter I measured the primary and I'm getting 179 ohms between red and blue, 119 between red and brown and 303 between blue and brown. I think red is the CT.
 I guess the amp could have worked the way it did. What say you about my findings? I would think the ct would be closer to center than 119 & 179. Is this ok?
I'm learning...
« Reply #69 on: August 06, 2020, 05:09:33 pm »
Is this ok?
:dontknow:
although I believe blue and brown are "typical" plate wires and red is CT, so wire it, try it, buy a proper OT if that don't get you happy
Offline JustMike
« Reply #70 on: August 06, 2020, 05:44:06 pm »
I tried it and I like it. Loud and clean. Thanks to all for your help and encouragement.
I'm learning...
« Reply #71 on: August 06, 2020, 08:09:50 pm »
Hooray!  You did it!  You got it solved!  And now you'll have a fine sounding amp.  Bravo!  Perseverance paid off!
 :headbang: :thumbsup:
With respect,  Jeff
Offline JustMike
« Reply #72 on: August 07, 2020, 10:10:16 am »
I've noticed that I'm getting some distortion when using a delay in the loop. It only occurs when I push the front end. I assume I'm overdriving the input of the Boss DD3, even when the send level is barely cracked. Would putting a resistor on the wiper of the send pot fix this? Or between the .002 and the send pot?
I'm learning...
« Reply #73 on: August 07, 2020, 01:47:55 pm »
Try reducing the value of the send pot. (if it is the 250K on the schematic I'm looking at)
You can do this easily by strapping a resistor across the outside lugs. 27K will make the pot approx. 25K and that could be enough to take care of your problem.
What tube type did you use for the FX?....it look's like tubenit used a 12AU7
« Reply #74 on: August 07, 2020, 04:45:38 pm »
Change the FX send to 25ka (if possible) and use a 12AY7 or 12AV7 or 12AU7
Offline JustMike
« Reply #75 on: August 08, 2020, 09:51:15 am »
I changed the pot to a 25k and I'm using a 12au7.It's a little better, but I've still gotta have the send pot below 2 to keep things clean. I know my pedals and cable are good. They work fine with my other amps. The fx send and return ARE the signal path to the PI and on. So the send level is used for matching to the input of the fx device and the return can be thought of as a "make up gain" level, right?
 And on another note, A friend who is a knowledgeable amp tech suggested I use 32u caps for the first 2 filter stages (this is when I had the distortion problem) and I did. I put in a F&T dual 32 can. There seem to be no problems, but I was reading on Rob Robinette's site that increasing those cap values in an AB763 will tighten up the low end, but I shouldn't exceed 60uf which is the limit for the deluxe reverb's rectifier. 32+32 exceeds 60 and we're using the same GZ34 rectifier.  Am I at any risk by doing this?
I'm learning...
« Reply #76 on: August 08, 2020, 12:50:43 pm »
Are we still working off of the schematic that tubenit posted in Reply #9 (Ryan's amp)?If so, I would view the FX level control as just a master volume.
To solve your problem you might have to insert a voltage divider after the .02 coupling cap that feeds the effects send triode. You can tentatively tack in a pot to come up with values.
I would also have to try snipping out the 330K parallel path around the FX loop, to see if that helps.
« Last Edit: August 08, 2020, 12:56:15 pm by SILVERGUN »
« Reply #77 on: August 08, 2020, 01:07:01 pm »
Where you have an 82k FX "return resistor" instead of a return pot, change that to 39k.  You can also change the 5uf cathode cap to 2.2uf on the return FX triode.
You can experiment by paralleling another 82k with the 82k FX return resistor using insulated alligator clipped wires. Then adjust the FX send pot.  Is it more to your liking now?
As an FYI,  I never have my FX send pot more than "5" and typically around 3.5.  I've tried 4 different delays and one reverb pedal and always end up with the same type setting.
I think it is sometimes a mental thing for us amp builders when we feel like some pot (vol, mstr vol, FX send etc...…) should be able to be set at " ______".
IF you can have the amp as loud as you want it and it sounds good and is clean as you want, then does it make any difference if the FX is set at "2"?
« Last Edit: August 08, 2020, 01:12:27 pm by tubenit »
« Reply #78 on: August 08, 2020, 05:07:50 pm »
+1!!
I've had to "re-do" a few builds because the players just can't get past the 0-10 dilemma  :dontknow:
might consider bypassing the tube feeding the FX send as a test, expect the pot might get to 7-10 then  :dontknow:
Offline JustMike
« Reply #79 on: August 09, 2020, 07:57:08 am »
 I understand the mental thing.
 What I realized I don't understand is how the whole loop circuit works. My understanding is; the 330k is the signal path when nothing is plugged into the send jack. But how V2 is wired is unclear to me. I'm used to seeing the stage output signal coming from the plate but here, it comes off the cathode. Why is that? Anybody want to teach me some tube theory?
 So once I find a good level setting on the send pot, I think I'm going to replace the pot with a fixed resistor. And the return level pot will then just be a master volume in my mind. An effects loop is something that I (and probably most guitar players) just want to be plug & play.
I'm learning...
« Reply #80 on: August 09, 2020, 09:12:27 am »
called a cathode follower, used for impedance "matching" typically < 1 for gain, no-inverting signal in/out
« Reply #81 on: August 09, 2020, 06:34:25 pm »
No, that resistor provides a parallel path around your effects pedal chain so that some of the signal stays un-effected into the recovery stage.
If you have the switching jacks wired like in the schematic, the switched terminals provide a signal path when nothing is plugged into either one of them.
Offline JustMike
« Reply #82 on: August 12, 2020, 10:12:33 am »
 So I came across a proper OT for this amp Classic Tone 40-18002. It has the same specs as the Hammond 1750H. Right now the amp has a xfmr out of a 2 6l6 amp with a 4 ohm secondary. I understand that running 6v6's into an 8 ohm speaker is a proper match. My question is does this "incorrect OT" give me any more headroom or output capability? I've heard that the Deluxe xfmrs compress due to saturation. I know this amp isn't exactly a Deluxe and has lower power.
I'm learning...
« Reply #83 on: August 12, 2020, 11:15:12 am »
"incorrect OT"
the OT doesn't really care as long as you get the "tube math" correct and the current limits.
the OT is the tubes "load", if you get it wrong, the tube works harder, less efficient, the tranny doesn't really care though, unless you exceed its thermal or current ratings, then maybe
Offline JustMike
« Reply #84 on: August 13, 2020, 10:43:28 am »
The amp sounds good. But honestly I think I'm having more fun learning and tweaking than I am just playing thru it. With that said, I'm thinking about trying a SS rectifier to tighten up the sound. My reasoning is that based on my sound- I like to run the amp on edge of breakup and hit the front of the amp with boost pedals for my lead sound, I don't want the amp to mush out (sag?) too much. I understand that a SS rectifier will raise the B+ a little and I'll also need a standby switch...or will I? When I search standby switch...well, it's like watching the evening news!
I'm learning...
« Reply #85 on: August 13, 2020, 11:39:57 am »
Two of my amps have a PT with 300-0-300 and 140ma.
Using a 5Y3GT,  I can run 6K6's or 6V6's.
Using a 5V4, I can run 6V6's or 5881/6L6
Using a GZ34, I can run 6V6's or 5881/6L6's
Using a plug in solid state rectifier, I can run JJ 6V6's or 5881/6L6
I've tried and done all of them in both amps.  Try out one of Hoffman's plug in solid state rectifiers and see if you like it better.  I use GZ34 (or 5V4) almost all the time.
« Reply #86 on: August 13, 2020, 01:16:19 pm »
never found a good use for SB switch (in an amp)
just consider your Ecaps, their VDC rating, before the filaments warm up, you may  exceed the vdc while waiting for the tubes
Offline JustMike
« Reply #87 on: August 19, 2020, 06:43:37 pm »
I've been playing with the circuit just to experiment and what I did was I took out the whole fx circuit. I'm going straight from the .02 coupling cap off of the plate of v2b into the input coupler on the P.I. I think I probably don't need both coupling caps? But I've noticed a drop in gain and volume. I think V2a being a cathode follower is unity gain at the most and V2b provides some gain in the circuit, correct?
I'm learning...
« Reply #88 on: August 19, 2020, 07:54:01 pm »
I
Yes, that is my understanding.
Why remove the FX loop?  You wanting less gain or is there some other issue?
As an FYI, you do have options of a parallel or series FX loop.  I've come to prefer a parallel one.
If you tell me what you're trying to achieve, I may be of some help to you.
