August 29, 2026, 04:55:18 pm
Hoffman Amps Forum image Author Topic: Single Input JCM 800 2204 clone  (Read 7694 times)
Offline MikePR
« on: June 05, 2020, 04:09:55 pm »
Just finished a Mojotone 2204 clone without the Low input jack but it seems I wired something wrong on the cliff jack. Here are some pics. Any idea was wrong? It sounds but with no Gain.
Thx
Re: Single Input JCM 800 2204 clone
« Reply #1 on: June 05, 2020, 04:54:17 pm »
Make the corrections shown in red...
Offline MikePR
« Reply #2 on: June 05, 2020, 07:08:25 pm »
Thx!! That worked. Another question. I want to remove the Presence knob. Could I connect the 4.7k to ground and remove the 22k pot plus the cap? Any recomendation?
Thx
« Last Edit: June 05, 2020, 07:16:29 pm by MikePR »
« Reply #3 on: June 05, 2020, 07:32:34 pm »
That'll work. You must keep the 4.7K.
Here's another way to do the same thing. Might be a bit neater...
Offline MikePR
« Reply #4 on: June 06, 2020, 04:00:31 pm »
Well that one did not worked. There is loud squeal coming from the amp. If i put a 25k pot with the .1 uf cap and 4.7k resistor the squeal only goes away when the pot is full.  :dontknow:
« Reply #5 on: June 06, 2020, 05:13:47 pm »
Yes it did, but it reveals that you have the NFB phase wrong. Swap the OT plate leads to correct.
Offline MikePR
« Reply #6 on: June 06, 2020, 06:30:05 pm »
Thx again! Did worked but had to change the OT pin 3 wires to each other and now is silent.
« Reply #7 on: June 06, 2020, 07:02:45 pm »
now is silent
Is that good or bad?
Offline MikePR
« Reply #8 on: June 07, 2020, 03:03:08 am »
Great!!!! 800 Growl. Thx again.
Offline MikePR
« Reply #9 on: June 11, 2020, 08:24:06 am »
The pilot light flickers every time i turn the amp out of stand by. Meaning on. Is there anything wrong? Do i need to add a cap between pilot light and switch so it does not do it?
