August 29, 2026, 05:53:21 pm
Hoffman Amps Forum image Author Topic: 6G3 Capacitor Question  (Read 103034 times)
Offline dwinstonwood
Re: 6G3 Capacitor Question
« Reply #200 on: July 13, 2020, 07:09:00 pm »
Thanks bmccowan!
I do enjoy projects more when I take my time. So much of this is new stuff that I like to finish a step and then look at for errors and then plan how and what to tackle next.
So, let me ask this. What gauge wire should I use for grounding? I haven't soldered up the ground wires to the chassis bolt yet because I wanted to get advice on that first.
Thanks.
« Reply #201 on: July 13, 2020, 08:55:23 pm »
I like 20AWG for power grounds and 22AWG for preamp grounds. Anything bigger that that red/yellow PT wire is overkill.
« Reply #202 on: July 13, 2020, 09:18:47 pm »
Thanks sluckey! I'm thinking stranded, not solid, since it's less likely to break under stress.
I'll replace those wires tomorrow, solder up the two ground bolts (one near the PT for power and another near the Normal input jacks for preamp), and get the main board in and connected up.
Then, I can power up without tubes and find out what happens!
BTW, I have a black car, and all I know is that white stuff is hard to wash off.
« Reply #203 on: July 15, 2020, 10:21:58 am »
OK, I'm trying to solve things myself instead of asking. :icon_biggrin:
My 1 Ohm cathode resistors are 1/2 watt. Let's say I measured a voltage drop of .05V. Converting that to .05 amps times the voltage equals .0025 watts. So, 1/2 watt resistors are plenty big for this application, yes?
« Reply #204 on: July 15, 2020, 10:44:04 am »
yes
:icon_biggrin:
« Reply #205 on: July 15, 2020, 07:06:33 pm »
Thanks shooter!
Here's my solution to installing the 1 Ohm resistors. Since pin 1 is not used - the JJ 6V6S's I bought don't even have a pin 1 - I used it to tie off the resistor.
Now, I can simply connect my test clip to the bare wire between pins 1 and 8 to take my readings.
« Reply #206 on: July 15, 2020, 08:25:16 pm »
I hate soldering a wire to a dangling end of a resistor. I like resistors to be firmly supported on each end. I would have mounted the resistor ***BETWEEN*** pins 1 and 8. Like this...
« Reply #207 on: July 15, 2020, 09:02:48 pm »
I like that!
I did notice that if the wire moves the the resistor moves, too. Over time it could get weak and snap off at pin 1.
Thanks!
« Reply #208 on: July 16, 2020, 11:01:15 am »
Going back and doing this over is like building three amps. :icon_biggrin:
The bright side is it's practice and the methods stick for future builds.
But, installing the main board and wiring it up is not something I want to do multiple times.
Is there anything wrong with my preamp wiring layout?
Thanks.
« Reply #209 on: July 16, 2020, 11:33:10 am »
what ground does the wire I indicated "feed"?
« Reply #210 on: July 16, 2020, 12:03:33 pm »
shooter, Fender has it indicated as a grounded wire.
It looks like part of the NF circuit.
« Last Edit: July 16, 2020, 12:06:30 pm by dwinstonwood »
« Reply #211 on: July 16, 2020, 12:13:14 pm »
that's the PI main ground for the "long tail"
I typically ground the PI with the PA circuit, not the pre circuit
« Reply #212 on: July 16, 2020, 12:26:21 pm »
See, glad I asked! :icon_biggrin:
Could I just run it into the doghouse hole and ground it at the negative end of the PA node one? It would be a much shorter wire that way.
« Last Edit: July 16, 2020, 12:29:22 pm by dwinstonwood »
« Reply #213 on: July 16, 2020, 01:37:33 pm »
short wires are good
I'd ground it with the cap I indicated
« Reply #214 on: July 16, 2020, 01:42:33 pm »
Oh...
I actually have that cap grounded with the 4th cap.
« Reply #215 on: July 16, 2020, 01:52:57 pm »
Oh...
And that's the way fender did it. I'd leave it just as your layout drawing shows.
« Reply #216 on: July 16, 2020, 02:19:36 pm »
I pointed it out not as a problem, but a potential one  :laugh:
« Reply #217 on: July 16, 2020, 02:50:47 pm »
Thanks. It's just as easy to ground it here:
« Reply #218 on: July 16, 2020, 03:13:42 pm »
wire it per Fender, should be fine.  IF there is a noise hum issue with PI, it's easy to change
« Reply #219 on: July 16, 2020, 05:05:12 pm »
Thanks.
I found a photo of an original 6G3.
It's hard to tell, but it looks like the ground wire is attached to the underside of the board and is then soldered to the long brass sheet that other preamp grounds are attached to.
(see red arrow)
I'll start with the wiring in post #208 first.
« Last Edit: July 16, 2020, 05:08:36 pm by dwinstonwood »
« Reply #220 on: July 17, 2020, 01:31:28 pm »
I reached a saturation point.
Going outside to get air.
« Reply #221 on: July 17, 2020, 06:02:15 pm »
I just need to solder up the power cord.
I'll go over every connection tonight, and once more in the morning, and then I guess it's dim bulb time.
Offline bmccowan
  • Better builder than player
« Reply #222 on: July 17, 2020, 06:19:11 pm »
Looking pretty good. A question. It appears that you have a white wire running from the fuse to the switch. When dealing with the house current side of the amp I think it best to stick to norms. White is neutral. Hot should run from fuse to switch to PT. Neutral should go directly to the other PT lead. Good sketch of that in both Doug and Sluckey's pieces. If I'm seeing the photo wrong, sorry, eyes are old.
Mac
John Prine
« Reply #223 on: July 17, 2020, 07:15:04 pm »
bmccowan, yes, you're right. I intend to wire it the way you're saying, I just used a spare piece of white wire I had. But, to avoid confusion I'll change it to a black wire! :icon_biggrin:
In looking at sluckey's layouts I see he wires his amps: line in > fuse > power switch > PT.
I've seen others put the fuse after the power switch, but I'll stick with his sequence.
Thanks! I'm almost at the end.
Offline bmccowan
« Reply #224 on: July 17, 2020, 08:01:02 pm »
Yup - that way you have fuse protection any time it's plugged in.
I'm hoping it fires right up with no issues. But if you have some - they should be easy to find as you have been methodical.
Mac
John Prine
« Reply #225 on: July 17, 2020, 08:19:55 pm »
Ha! I was just in there soldering up the power cord and noticed that I attached the V1 plate wire to pin 9, not pin 1. Fixed it.
It would not have fired right up. :laugh:
Here's the proper power cord wiring. Thanks again for calling that out.
Offline bmccowan
« Reply #226 on: July 17, 2020, 08:32:40 pm »
I have done things like that so often it's not funny. Just recently I confused pins 1 & 8 on a 6V6. That did not work out so well!
« Last Edit: July 17, 2020, 08:37:57 pm by bmccowan »
Mac
John Prine
« Reply #227 on: July 17, 2020, 08:44:33 pm »
Just recently I confused pins 1 & 9 on a 6V6. That did not work out so well!
  :huh:
« Reply #228 on: July 17, 2020, 08:51:23 pm »
pin 8?
Offline bmccowan
« Reply #229 on: July 17, 2020, 09:29:29 pm »
Yup - typo I corrected - fat fingers and good wine!
Mac
John Prine
« Reply #230 on: July 18, 2020, 08:07:12 am »
Hoffman:
"Double check all your work:
Stop now and look at this post on my forum on how to double check all your work, this is very important
How to double check your work the easy way
Do not continue until you have double checked everything using my method above
Every time someone has an issue with the amp not working it is always because they skipped a step or did not double check their work thoroughly.
Hoffman law says this.
The amp would be working if it was wired properly and all the parts were installed and working correctly."
A voice is saying, "Aw, you can skip all that! You took your time and worked carefully."
Nope. I"m following the rules. :icon_biggrin:
« Reply #231 on: July 18, 2020, 10:45:26 am »
I've started measuring voltages.
With no tubes installed:
Pilot light glows.
40 watt dim bulb just barely glowing.
No smoke. No pops. No sparks.
Looking into chassis from the top (open side). Control panel facing away.
Right 6V6 tube socket grid - bias pot gives range of -61.4v to -45.8v
Left 6V6 tube socket grid - bias pot gives range of -61.5v to -45.8v
This is with a 470 Ohm bias resistor, 10K pot, and 27K safety resistor on the pot.
With no tubes - including no rectifier - no voltage on any of the six preamp tube plates and no voltage on the power tube plates or screen grids.
What should I do next?
« Last Edit: July 18, 2020, 12:14:39 pm by dwinstonwood »
« Reply #232 on: July 18, 2020, 11:06:38 am »
next?
got filament volts were they belong?
IF so;
put rectifier only in and verify the PS makes VDC
IF so
probe the plate pins and make sure the DC is there;
IF so;
add preamp tubes, set your bias to max neg, measure vdc at plates and cathodes.
IF good-ish;
did you install 1 ohmers?
IF so, set up a meter to read across one, install PA tubes and get a quick read on the one ohmer's, do the math and evaluate
« Reply #233 on: July 18, 2020, 11:07:56 am »
I'm also measuring 6.33V AC on pins 4 & 5 of the first 12AX7.
Unfortunately, my tubes haven't arrived yet! AES is not the fasted shipper. :icon_biggrin:
Anyway, I suppose - with guidance - I can tweak the bias resistors to get the negative voltage range I need for the JJ 6V6S's.
Thanks.
Offline punkykatt
« Reply #234 on: July 18, 2020, 11:13:34 am »
you have the 1 ohmers install wrong. Put the ground wire on pin one.
« Reply #235 on: July 18, 2020, 11:16:29 am »
Thank you punkykatt!!! Dang! I would have gotten different measurements and probably never figured out why.
Thank you!
« Reply #236 on: July 19, 2020, 11:20:12 am »
I take that back. They arrived today! Less than a week is pretty fast.
But, I found another big mistake in my work. I need to redo the heater wiring. I did it all wrong. It took me a long time to find photos of how to do it. I'm also out of solder, but that is supposed to also arrive today.
You either get frustrated and shelve it, or, you try to look at it as gaining experience. Perspective...
Offline bmccowan
« Reply #237 on: July 19, 2020, 04:05:47 pm »
I just looked at your pics to see the heater wiring. You connect pins 4&5 but not 9 on the preamp tubes? You probably found the solution, but good heater wiring instructions here:
http://www.valvewizard.co.uk/heater.html
Mac
John Prine
« Reply #238 on: July 19, 2020, 04:26:23 pm »
Yep! That's apparently series for a 12.6v secondary. :BangHead:
I just got it fixed. I'm measuring 6.35V AC down the line.
OK, so I have the tubes. I guess the next thing to do is to install the rectifier and check for plate and screen voltages? This is the part where I get apprehensive. I'll be charging the filter caps.
I'm going to take a breather and eat. I just spent an hour twiddling with those tiny socket pins to get the heater wiring right. I want to approach this with a calm and alert state of mind. :icon_biggrin:
« Reply #239 on: July 20, 2020, 04:25:03 pm »
I had some free time to take more measurements.
With ONLY the rectifier in:
Right 6V6S Plate Pin 3 = 325.1VDC
Right 6V6S Screen Pin 4 = 324.8VDC
Left 6V6S Plate Pin 3 = 325.2VDC
Left 6V6S Screen Pin 4 = 324.7VDC
Should I measure all of the 12AX7 plates, too, at this point - with no tubes installed?
Also, since I have the cap pan screwed on and the caps are under the chassis, anyway, I've been draining the filter caps at the point in the image. Is that a good, reliable place to drain them? I'm being ultra safety conscious!
Thanks.
« Reply #240 on: July 20, 2020, 04:29:14 pm »
the reason I poke the no tube plates is to "catch" a wiring error befor it puts 300vdc on the grid, instead of the plate.
your drain hole is good, what are you using?
« Reply #241 on: July 20, 2020, 04:43:22 pm »
Thanks!
I made a discharge tool. I might could have used a smaller resistor, it takes about 3 minutes to drain the caps down to zero. Plus, I might add a clip instead of the probe, but I don't want to forget it's connected! The probe is sort of idiot-proof in that regard. Plus, it makes me stand there and watch the meter.
OK, I measured all six of the 12AX7 socket plate pins:
V1 - pin 1 = 315.0VDC
pin 6 = 315.4VDC
V2 - pin 1 = 319.1VDC
pin 6 = 318.8VDC
V3 - pin 1 = 322.2VDC
pin 6 = 321.7VDC
Just to consolidate numbers. Here are the grid negative voltage ranges. I have the pot set to maximum negative voltage.
« Last Edit: July 20, 2020, 05:02:49 pm by dwinstonwood »
« Reply #242 on: July 20, 2020, 05:09:34 pm »
one like I used in my career days  :icon_biggrin:
« Reply #243 on: July 20, 2020, 05:29:16 pm »
 :icon_biggrin: I like the C-clamp ground. It shouldn't accidentally come loose! How many volts were you dealing with?
« Reply #244 on: July 20, 2020, 05:36:17 pm »
Too high for 6V6s. Shoot for a range of about -20 to -40. Change that 470Ω bias range resistor on the bias board to 1K and see if that gets you there. If not, experiment with that resistor value to give those 6V6s what they need. Fender claimed -26v on the original but since your B+ is gonna be lower your bias voltage will probably be lower too.
« Reply #245 on: July 20, 2020, 05:51:20 pm »
Thank you sluckey!
I bought a range of resistors from 470, 1K, 4.7K, 8.2K, to 10K. I'll get the bias pot to cover that -40-ish to -20-ish range next.
I might wire up some clip leads so I don't have to solder in resistors between each test (thinking out loud).
But, so far, no shorts, smoke or sparks!
Offline 66Strat
« Reply #246 on: July 20, 2020, 06:20:46 pm »
Those B+ voltages look low. Were the voltage readings taken with the current limiter light bulb in circuit? What are the AC secondary voltage readings, and how do they compare to the transformer's published specifications?
Regards,
JT
« Reply #247 on: July 20, 2020, 06:39:38 pm »
reply #68 has 270-0-275, tube rec?, if so I'd think 325vdc would be close, loaded 290?
« Reply #248 on: July 20, 2020, 07:00:15 pm »
Thanks.
Yes, the dim bulb tester was being used. Now that I know there are no shorts I can measure again without that in series.
But, I did intentionally go with a PT with lower secondary voltages than the AB763 Deluxe Reverb PT that Hammond suggests for this amp.
I'll post voltages without the dim bulb.
« Reply #249 on: July 20, 2020, 07:15:33 pm »
Thanks for reminding me about the dim bulb tester 66Strat.
No power tubes: Plate on the right 6V6 socket now measures 417VDC, and the left socket is 418VDC.
With tubes installed I might actually be near my target voltage of 375, or somewhere near the schematic voltage of 365. I don't know how much the 6V6S's will drop the voltage to be honest.
