September 10, 2026, 01:19:22 am
Hoffman Amps Forum image Author Topic: Leo style combo cab cuts  (Read 8426 times)
Offline Sonny ReVerb
  • Possibly another stupid question...
« on: June 18, 2020, 02:23:01 pm »
Hey all, I thought I'd share a jig I made today for my table saw.
 I've cut a couple cabs with Leo style angled fronts. They've always been difficult to manage on the table saw because of the size of the cab. So, I decided to make up a jig to do the tapered cuts. I used a 1/2" thick piece of MDF about 12" x 24" for the base. I added a 3/4" thick toe board on each end and a stop in the middle for support. Then I added a clamp to secure the cab during the cut. It turned out pretty well and made the cuts easier than ever before.
Re: Leo style combo cab cuts
« Reply #1 on: June 18, 2020, 02:24:35 pm »
More pics:
« Reply #2 on: June 18, 2020, 02:26:14 pm »
Resulting cut:
« Reply #3 on: June 18, 2020, 02:29:51 pm »
Once the taper cut is made on each side of the front, the top cut is made by angling the table saw blade. After some high school math, I came up with 25 degrees.
« Reply #4 on: June 18, 2020, 02:32:15 pm »
The results were satisfactory when I did a test fit. The 25 degree angle is very close to parallel with the chassis face.
Offline Joe Garfield
« Reply #5 on: October 06, 2020, 12:56:19 am »
Very nice! I would have been nervous making those cuts after the dovetails were done.
« Reply #6 on: October 09, 2020, 06:04:11 am »
Good point. Maybe I'm going about the process in the wrong order. Anybody cut the sides to shape before assembling the box?
Offline Latole
« Reply #7 on: October 19, 2020, 03:52:18 am »
It is not a problem if you measure twice and you cut once.
Sonny Reverb do a good job.
This is probably not the best way for mass production, but here it does not matter,
Job well done Sonny Reverb  :worthy1:
