September 15, 2026, 11:02:02 pm
Hoffman Amps Forum image Author Topic: Flipped inputs  (Read 4794 times)
Offline Rp3703
  • Inexperienced Expert
Flipped inputs
« on: June 19, 2020, 07:01:48 am »
If you rotate the Cliff input jacks from the way they are usually facing, is it ok to wire all the sleeve contacts together like in the drawing attached? Just want to make sure there is not something I'm missing.
Re: Flipped inputs
« Reply #1 on: June 19, 2020, 07:36:03 am »
That's fine. Looks neater IMO.
Offline Rp3703
Re: Flipped inputs
« Reply #2 on: June 19, 2020, 07:45:33 am »
Ok, yeah, I saw that drawing but did not realize it is the same as mine since the HI LO inputs are in opposite positions. I relabelled mine to make more sense. Thanks.
