September 16, 2026, 04:21:57 pm
Hoffman Amps Forum image Author Topic: Princeton Reverb build  (Read 4101 times)
Offline labb
« on: August 02, 2020, 08:26:50 am »
Just finished building the PR without reverb or trem and it turned out pretty good. The amp is really quiet. You don't know it is on untill you hit a note. Seems to start breaking up at about 12:00 on the volume . Only issue so far is that the dang thing is really loud. At 2 on the volume it is shaking the walls. When I can get it back from the player I will install a MV. That should fix it. I was intending to post some pics but I saw P2P's pic and don't want to shame myself..Take care, be safe...
« Last Edit: August 02, 2020, 09:27:28 am by labb »
Offline vampwizzard
    • Walbertedwards.com
Re: Princeton Reverb build
« Reply #1 on: August 02, 2020, 12:21:56 pm »
no shame in where your skills are at right now! Which PR did you do? Blackface? Did you keep the reverb load resistor/filter cap in there?
Offline labb
« Reply #2 on: August 02, 2020, 12:53:53 pm »
AA1164 and yes on reverb load resistor and cap..I did cheat a little the transformers are over sized, 330-0-330 volt 120 ma. the OT is 20 watt. basically the deluxe transformers. Running 450 v. on the 6V6 plates, 155 v. on the pre amp tube plates and 185 v on the PI. I gave it a mid range pot and it is set up to switch out the tone stack.
Offline vampwizzard
« Reply #3 on: August 02, 2020, 02:34:40 pm »
awesome! would love to see pics of it!
