September 15, 2026, 04:40:06 am
Hoffman Amps Forum image Author Topic: Trem-o-nator schematic & layout question?  (Read 3901 times)
« on: August 14, 2020, 09:13:29 am »
I am often wrong and could be on this also?
It appears there is a discrepancy in some of the schematics and layouts showing the vactrol wiring for the trem-o-nator?
Can someone help me get this straightened out in my thinking, please?
My trem-o-nator works fine in my amp, I am just trying to get my documentation to be consistent.
Thanks, Tubenit
Re: Trem-o-nator schematic & layout question?
« Reply #1 on: August 14, 2020, 09:48:47 am »
That part of the Vactrol is just a resistor. And like a resistor, it makes no difference which way it it connected. I'm guessing this is related to the thread on TAG?
« Reply #2 on: August 14, 2020, 10:42:44 am »
I wondered if that was the case.  Yes, the TAG thread prompted my reviewing of what I had in documentation.
THANKS!  Tubenit
Offline yorgle
« Reply #3 on: August 14, 2020, 02:22:10 pm »
Somewhat related to this- even though it's just grounding the signal, should wires in that path be shielded?  I ask because in my latest build, I'm getting a slight buzz that varies with the trem speed and disappears altogether when the resistor side of the vactrol is disconnected from the volume pot.
« Reply #4 on: August 14, 2020, 09:34:01 pm »
Or minimized.
It's gotta be a high-impedance point. So the more wire you hang off it, the more crap it will pick up. The LDR can perhaps be right AT the audio path; the LED wires can be long.
