September 14, 2026, 10:57:14 pm
Hoffman Amps Forum image Author Topic: Setting your board dimensions in DIYLC  (Read 47256 times)
« on: September 04, 2020, 03:51:30 pm »
If you are using my DIYLC analyzer program and your board length is not showing correctly, make sure you set the board sizing mode correctly in DIYLC
There are two sizing mode methods in DIYLC to set your board length
Opposing Points or Explicit Dimensions
Opposing points is when you grab the edges of the board and drag it out to the size you want
Explicit Dimensions is where you type in the exact dimensions of the board in the Edit Selection box
You can set your board length either way
The height of Hoffman custom boards is always 3.125 inches
The DIYLC program shows this as Explicit width if you use that method
Whatever shows in the explicit length and width boxes will not be used if you set the sizing mode to Opposing points
See my screen shots below
