September 16, 2026, 02:58:31 pm
Hoffman Amps Forum image Author Topic: Dual Tremelo = Auto Pan?  (Read 14668 times)
Re: Dual Tremelo = Auto Pan?
« Reply #50 on: September 19, 2020, 04:37:35 pm »
I'm gonna butcher this, someone else cane decode it  :icon_biggrin:
You do start with tubes
then tube datasheet
find what "operating conditions" you want, or are constrained by (you have trannies and just gotta make them "fit"!)
here's a datasheet from my last build;
my "target" is inside the red box
note plate to plate effective resistance is 12k
I had a 5K:4ohm
if you double the "load" (speaker) to 8ohms, the pri side doubles too, so 10k
now I build it, dial B+ like the datasheet says
use a cathode R like the datasheet says
then tinker tweak close
once I get "there", the tubes "should be happy" with the OT conditions, give or take a few  :icon_biggrin:
Offline neddyboy
« Reply #51 on: September 19, 2020, 08:03:10 pm »
Give me a day or two to unpack all that! Thanks for the explanation.
