September 18, 2026, 12:46:05 am
Hoffman Amps Forum image Author Topic: Silver tone 1396  (Read 5665 times)
Offline Big chief
Silver tone 1396
« on: October 03, 2020, 09:54:37 am »
Silver tone 1396 no power to 5U4 rectifier tube or 12ax7 all other tubes light up
Low voltage on all other tubes pin 3 on6l6 should be 340 meter shows 0. 5u4 pins 4, 6
Should be 360 shows O
Any help would be great
Offline Latole
Re: Silver tone 1396
« Reply #1 on: October 03, 2020, 10:28:20 am »
It is not what I call low voltage. It is NO voltage  :laugh:
Schematic ;
http://schems.com/bmampscom/silvertone/silvertone_1396.pdf
Fuse is good ?
Is your meter working and is on AC scale ?
1- Do you have 120 volts at P.T primary ?  If Yes
2- Remove all tubes 5U4, 12XX7s , 6L6s All
3- Read voltage at 5U4 socket between pins 4-6. ; close 360 V ac
              "                        "                         2-8  : close o 5 V ac
    No voltage:  look P.T. is blow
4- Read winding ohms as show ;
    You will find a open winding
« Last Edit: October 03, 2020, 10:45:11 am by Latole »
Offline Latole
« Reply #2 on: October 03, 2020, 10:45:44 am »
« Reply #3 on: October 03, 2020, 11:00:24 am »
...all other tubes light up
...5u4 pins 4, 6 Should be 360 shows O
Since you have filaments the PT is receiving primary voltage. But, since you have zero VAC on pins 4 and 6 of the 5U4, it's likely that the PT HT winding is faulty. You did have your meter set to read AC voltage when you checked pin 4 and 6, right?
BTW, the 12AX7s get their filament voltage from the cathodes of the 6L6s, so they will ***NOT*** be lit until you have proper plate voltage on the 6L6s.
Offline Big chief
« Reply #4 on: October 03, 2020, 11:14:46 am »
Have 0 on pins 2-8. 0 on 4-6 have 120 at switch 0 on fuse holder replaced fuse twice
All tubes pulled  fuse holder seems ok have .05 ohm
« Reply #5 on: October 03, 2020, 11:35:21 am »
Is your meter set to measure AC VOLTS?
To correctly measure the 5VAC winding, you must put one meter probe on pin 2 and the other meter probe on pin 8. Pins 4 and 6 can be correctly measured with one probe connected to chassis.
Offline Latole
« Reply #6 on: October 03, 2020, 01:17:26 pm »
Answer no 1 : Is your meter working and is on AC scale ?
Look is not
Test with wall outlets
Offline Big chief
« Reply #7 on: October 03, 2020, 02:33:00 pm »
Meter is working and was on ac I did exactly as you stated I put test leads on 2-8 no voltage I’ll try to take some photos and post
4-6 no voltage
Offline Latole
« Reply #8 on: October 03, 2020, 02:56:21 pm »
4-6 no voltage
PT is burn, no need more test.
You read ohms for fun on each PT coil as my screen print show
Offline Big chief
« Reply #9 on: October 03, 2020, 03:24:16 pm »
Thanks to all for your help will try to find a PT
