September 16, 2026, 04:04:23 pm
Hoffman Amps Forum image Author Topic: 93 Fender Super Humms  (Read 4541 times)
Offline JustMike
« on: December 02, 2020, 09:26:35 am »
 This amp was in a Beach bar for years. I cleaned it up, recapped it, replaced the 6l6's and one bad 12ax7. It works, but there is a 120hz(?) hum present all the time and it's not affected by any volume control. It doesn't change when I insert a cable to the front input jacks or the send & return jacks. The caps I replaced were the 7- B+ caps. I suspect there may be a corroded or rusted ground connection? Anything else I should be looking for? preamp tubes perhaps?
« Last Edit: December 02, 2020, 09:29:43 am by JustMike »
I'm learning...
Offline Latole
Re: 93 Fender Super Humms
« Reply #1 on: December 02, 2020, 09:47:08 am »
Is the hum was there before you work in ?
And what about bias caps ?
You can check ripple to see if they are bad or not
Clean all tubes's sockets.
Any mod on the amp ?
« Last Edit: December 02, 2020, 10:07:49 am by Latole »
Offline Latole
« Reply #2 on: December 02, 2020, 10:07:02 am »
Did you put filter caps with polarity ?
Check ripple ; no more than fews AC volts
Offline JustMike
« Reply #3 on: December 02, 2020, 10:14:15 am »
Thanks Latole, but I don't have a scope.
I'm learning...
Offline Latole
« Reply #4 on: December 02, 2020, 10:15:41 am »
You don't need a scope , use voltmeter in AC scale.
Is the hum was there before you work on amp ?
Offline Latole
« Reply #5 on: December 02, 2020, 10:28:10 am »
Check if heater ground through 47 ohms resistor is good
