August 29, 2026, 07:34:32 pm
Hoffman Amps Forum image Author Topic: Sunn 200s bias resistor  (Read 17521 times)
Re: Sunn 200s bias resistor
« Reply #50 on: January 18, 2021, 09:46:10 am »
these GLs are Cryo'd. Does that change things?
only the diameter of your money roll  :icon_biggrin:
I got to play with cryo's for a living, it is fun to freeze things, shatter roses, hotdogs, etc.  Improving tube performance......
I did freeze a bad tube, but it shattered  :sad2:
Offline pbman1953
« Reply #51 on: January 18, 2021, 09:52:31 am »
Ya, cryo, not for me. I guess my friend fell for that. I do have to say that this pair are very close in matching. Upscale does a good job with that.
« Reply #52 on: January 18, 2021, 12:27:33 pm »
The pot min/max is now -63 to -79. With the Bias Rite I'm getting it to settle around 28 watts
Never got down to your desired 22-23 watts. And when/if you change tubes to another brand you'll need to read this thread in reverse to return the bias circuit to original values.   :icon_biggrin:
Offline pbman1953
« Reply #53 on: January 18, 2021, 12:40:19 pm »
You have seen a range from 22 but I really wanted mid to high 20's. The next thing this needs is new sockets. All these old amps have  wiggly sockets. If he makes a change I'll deal with it.
Thanks for the help
« Reply #54 on: January 18, 2021, 01:00:34 pm »
Hmm, in reply #10 you said you wanted 22 to 23 watts. But you never reported you had 22 watts in this entire thread. And you also never said you really wanted mid to hi 20s.
Offline pbman1953
« Reply #55 on: January 18, 2021, 01:30:43 pm »
I stand corrected i wanted higher in the end
