September 08, 2026, 11:28:31 am
Hoffman Amps Forum image Author Topic: Cap replacement question  (Read 6134 times)
Offline pbman1953
« on: January 25, 2021, 04:05:38 pm »
I was installing my new filament transformer in my 2000s and by accident a cap was damaged.
Seems to be the "C" connection that has a pair of 20uf's at 450V. I have a new 80uf at 500v. Is it too large a value or simply overkill and use it since I have it?
Re: Cap replacement question
« Reply #1 on: January 25, 2021, 04:10:50 pm »
Isn't one of those 20µF caps inside a multi-cap can?
Offline pbman1953
« Reply #2 on: January 25, 2021, 04:12:57 pm »
Sorry I didn't mention , this has had a cap job years ago and it's all discrete
« Reply #3 on: January 25, 2021, 04:36:51 pm »
I'd use it to replace both of the parallel 20s. Might even be an improvement in a Bass amp.
Offline pbman1953
« Reply #4 on: January 25, 2021, 04:42:14 pm »
So you're saying I have  a green light for the 80uf?
Also , should I check the bias?
« Reply #5 on: January 25, 2021, 04:46:16 pm »
Why do you need a new filament transformer?
Offline pbman1953
« Reply #6 on: January 25, 2021, 04:48:55 pm »
For the Kt120's, to be safe. I got a 6.3 @ 10amp
Also is there any advantage to up the value for the "B" line? I have another 80uf
Offline thetragichero
« Reply #7 on: January 25, 2021, 05:00:32 pm »
any reason you're switching to kt120s? is it just because 120 is bigger than 88/60 is bigger than 42? will those transformers have enough current capability (b+ and output) to make the switch worthwhile?
Offline pbman1953
« Reply #8 on: January 25, 2021, 05:04:20 pm »
For me they are so worthwhile, blame Ed Chambley, in good way. For me nothing beats them. I wanted to help the amp , based on Ed's and a high end tech that used to work for Ampeg to install the FT.
Offline pbman1953
« Reply #9 on: January 25, 2021, 07:21:11 pm »
« Reply #10 on: January 25, 2021, 07:22:14 pm »
Try it and see.
Offline pbman1953
« Reply #11 on: January 25, 2021, 07:23:45 pm »
