September 14, 2026, 01:41:32 pm
Hoffman Amps Forum image Author Topic: Marshall 1987s hum.  (Read 6645 times)
Offline Rich_C
Marshall 1987s hum.
« on: March 05, 2021, 11:52:53 am »
Hi,
I installed new F&T filter caps into my amp and its developed a hum. No hum in standby, but it's there when no guitar is plugged in. I can't decide if it's a 60 cycle hum of 120 cycle hum. I'm leaning towards a 120 cycle by the pitch. I also put new tunes throughout, to rule out a bad tube I put the old tubes back in...noise remained. Has anyone ever purchased a new filter cap and gotten a bad one? I was poking around yesterday and discovered one of the pins on a preamp socket makes noise when poked. But i think this is an unrelated problem.
Offline Leevi
    • Rikstone
Re: Marshall 1987s hum.
« Reply #1 on: March 05, 2021, 12:22:06 pm »
Do you mean that the hum increased after cap replacement?
/Leevi
Offline Latole
« Reply #2 on: March 05, 2021, 12:34:43 pm »
Something wrong with your soldering or you put filter cap backward ?
Check your work.
I never had a bad filter filter cap from a store.
In Stanby, there is no B+voltage. So you can't hear a sound or hum or hiss in the speaker.
« Last Edit: March 05, 2021, 12:38:24 pm by Latole »
Offline Rich_C
« Reply #3 on: March 05, 2021, 02:05:53 pm »
Leevi ~ Yes, increased after caps were change.
Offline Latole
« Reply #4 on: March 05, 2021, 02:07:56 pm »
Check you work .
Offline Rich_C
« Reply #5 on: March 05, 2021, 02:22:50 pm »
Latole ~ I thought it could be a bad solder job. They seems tight. But who knows. I was very careful to hook them up correctly. I suspect if it is a bad joint...its probably the one under the PCB. That wasn't easy to get at. Marshall was a bit skimpy with wire back in 1988.
Offline Latole
« Reply #6 on: March 05, 2021, 02:40:32 pm »
I don't know if it is a bad solder or something else.
Every time amp is worse after I work on, it was my job, my fault.
And I read the same about other forum members
Offline Rich_C
« Reply #7 on: March 05, 2021, 03:06:01 pm »
Latole ~ I hear ya. Wouldn't be the first time I made things worse. I'm going to go in and take another poke around. Only other thing running through my mind is the Bias caps. I didn't change them. With my lack of soldering skills, I wanted to keep away from the PCB. Anyhow, I'll see how it goes.
Offline Leevi
    • Rikstone
« Reply #8 on: March 05, 2021, 11:24:42 pm »
The problem can be somewhere else, the new filter caps just made it louder. If you have an oscilloscope check for instance if there is ripple on the negative bias voltage.
/Leevi
Offline Rich_C
« Reply #9 on: March 06, 2021, 03:47:04 pm »
That sounds reasonable to me. I don't have an oscilloscope. I think for my sanity, and the health of my amp, I'm going to have to get a pro involved.  "A man's GOT to know his limitations" ~ Harry Callahan  :icon_biggrin:
Offline acheld
« Reply #10 on: March 06, 2021, 09:30:40 pm »
Hah!   Not in today's world . . .
Offline Rich_C
« Reply #11 on: March 08, 2021, 12:33:11 pm »
 :laugh: Yeah. But experience is a valuable thing.
Offline Tone Junkie
« Reply #12 on: March 09, 2021, 03:03:09 am »
Jump in there give it a shot. 13 yrs ago these guys helped me build a 1987. I’m sure some of them would have liked to strangle me during trouble shootIng. my soldering skills Weren’t quit up to par, but they stuck with Me . just like they will with you. now I have 35 or 40 amps under my belt. Still make dumb mistakes. And they continue to help me. Great bunch of guys.
