October 04, 2026, 10:58:16 pm
Hoffman Amps Forum image Author Topic: New Files with parts added - Fender AB763 and Hoffman AB763  (Read 42165 times)
I uploaded a couple new .diy files to the library.
One is a fender AB763 reverb amp with the parts.
This is located in the Fender DIY Files section.
The other is a Fender Trem Opto as seen on the AB763 board above.
This is located in the template files section.
I had to create the opto from scratch and save it as a building block.
The Read_me files in each section have info on how to download and-or import building blocks into DIYLC.
This is a low res screen shot of the AB763 Board. You can see the Opto I created as a building block.
The DIYLC library is here.
https://el34world.com/charts/DiyLayoutCreatorFiles.htm
« Last Edit: May 17, 2021, 08:49:56 am by EL34 »
Re: New Files with parts added - Fender AB763 and Hoffman AB763
« Reply #1 on: May 17, 2021, 09:00:28 am »
Here's the Hoffman one channel AB763 with parts added
You can copy and paste many of these parts to other Hoffman boards
The same patterns appear on many other boards
Channel one is the same as channel two on AB763 boards
So, no need to start from scratch on your project
The file name is Hoffman_Layout_With_Parts.diy
It is located on this page in the DIYLC library
https://el34world.com/charts/DiyLayoutCreator/files/Hoffman_Diy_Files/Hoffman_Diy_Files.htm
Here's a screen shot of this board
