August 29, 2026, 07:30:08 pm
Hoffman Amps Forum image Author Topic: beginner bass tube amp build  (Read 4152 times)
Offline luthierwnc
  • Should I mod this one or make another?
« on: May 09, 2021, 09:09:07 am »
Hi All,
Nutha annoying question:
An old friend told me he wanted to take up the bass to play with friends now that they can get together again.  He has Parkinsons so this will be a gradual situation.  I ordered a decent bass, cords, et al which he can practice without an amp.  There are amps where the guys get together.  As everyone on this forum knows, that will get old if he makes much progress.  Other than big, powerful bass tube amps, I don't have much experience in that realm.  I'd like to know if anyone has a recommendation for a compact unit -- probably a head/cab -- that will push enough air to hear in his living room.  The output should be as clean as is reasonable.
And I'm not married to tubes for this.  If a solid-state unit out there in the market will do that with less weight, that's definitely a candidate.  If I get a head, I'll probably make a pine, single-12, cab to go with it.
As always, thanks for looking and I'll look forward to ideas, Skip
« Last Edit: May 10, 2021, 12:57:04 am by luthierwnc »
Re: beginner bass tube amp build
« Reply #1 on: May 09, 2021, 09:16:01 am »
I would look on eBay or reverb for a SS Peavey.
Offline luthierwnc
« Reply #2 on: May 09, 2021, 09:34:31 am »
Yep!  Lots of people selling stuff under their kid's bed.  Thanks, sh
Offline echuta13
  • Elder God
« Reply #3 on: May 09, 2021, 05:15:29 pm »
If weight is an issue, I would suggest something along the lines of a Fender Rumble 40 which comes in around 18lbs.  It's 40 watts which isn't huge, but enough for a coffee shop perhaps.
"When choosing between two evils I always like to try the one I've never tried before."
Offline j_bruce
« Reply #4 on: May 09, 2021, 08:19:24 pm »
I have a Fender Rumble 100. What a great little amp for your situation.
it has enough power to handle anyone's living room and small jam session or garage band duty. It also has a very light weight speaker so it is not too hard to lug around. It also has a variety of presets that should suit your friend's adventures. There is a 40 watt version out there too, which might be the perfect at home bass amp for a beginner.
