September 15, 2026, 08:54:54 am
Hoffman Amps Forum image Author Topic: Matchless Clubman Question  (Read 9229 times)
Offline jackplug1
« on: May 21, 2021, 02:04:48 pm »
I have built a Matchless clubman clone which appears to have excessive plate dissipation using this calculator:
https://robrobinette.com/Tube_Bias_Calculator.htm
Plate to cathode voltage: 402v
Tubes that share a cathode resistor: 1
Voltage across cathode: 28v
Cathode resistor: 330R
= Plate current 80.1Ma
= Dissipation per tube 32.2watts
It appears that the safe limit should be 67.2Ma
Should I increase the cathode resistor to about 600R?
The amplifier appears to run hot and is very loud for a 35watt amplifier although it sounds quiet bright and lively.
Running at these levels will the life of the output tubes be short but very gay?
Offline Latole
Re: Matchless Clubman Question
« Reply #1 on: May 21, 2021, 03:15:34 pm »
Wich tubes ? EL34  ?
Schematic here ;
https://www.thetubestore.com/lib/thetubestore/schematics/Matchless/Matchless-Clubman-Schematic.pdf
80 ma is for resistor dissipation, not for tube dissipation ?????
I may be wrong too  :BangHead:
« Last Edit: May 21, 2021, 03:25:29 pm by Latole »
Offline jackplug1
« Reply #2 on: May 21, 2021, 03:19:25 pm »
The Matchless Clubman output tubes are EL34
Offline Latole
« Reply #3 on: May 21, 2021, 03:23:03 pm »
In class A EL34 can hold 56 ma for 400 volts /plate
Class AB 43 ma
« Last Edit: May 21, 2021, 03:28:50 pm by Latole »
Offline Latole
« Reply #4 on: May 21, 2021, 03:28:12 pm »
I'll increase the resistor for each tube, your calculation look right.
Do you use one resistor for each tube or one resistor for both tubes ?
__________________
"It appears that the safe limit should be 67.2Ma"
This wrong. Not more than 56 ma. You make a mistake in calculation
« Last Edit: May 21, 2021, 03:31:25 pm by Latole »
« Reply #5 on: May 21, 2021, 07:22:07 pm »
Why build a clone and then change a key aspect of what made the original what is was? eg super hot idle.
For a cathode biased amp, the anode voltage is somewhat greater than the anode to cathode voltage.
And cathode current equals anode current plus screen grid current.
« Reply #6 on: May 21, 2021, 09:28:12 pm »
Allowing for screen current, it may be 27 Watts in the plate. The book says 25W. Every EL34 I ever abused would take 30 Watts for days. And that seems to have been standard practice with amp designers for decades. Any current tube-maker knows that, and must allow for it or be drowning in warranty claims.
600r is surely too much. 380-420 may be worth a try. But as said: don't be timid and accept boring tone. EL34 is about the cheapest big tube around, the 5-cent cigar of the tube world.
« Reply #7 on: May 22, 2021, 03:07:16 am »
If we accept that the 6L6GC has an anode dissipation limit of 30W, then under that same design max rating system, the EL34 limit would probably be about 29W.
Offline jackplug1
« Reply #8 on: May 22, 2021, 07:35:01 am »
__________________
One resistor per tube:
If you click on the link the calculation is done for you.  You just fill in the values
Offline jackplug1
« Reply #9 on: May 22, 2021, 08:07:25 am »
The output tubes do not share a cathode resistor, there is a separate resistor or for each tube
I had another look at it, I think I have misinterpreted the results on reflection
The total plate current is 80.1ma divided by 2, so it's 40.05ma per tube.
Plate current per tube is plate current PER TUBE minus plate voltage is 17.4watts per tube
err .. I think, Is that right?
The calculator does not have an input for how many tubes there are.
Maybe sombody could have a look at that tube bias calculator to clarify things
« Last Edit: May 22, 2021, 08:28:38 am by jackplug1 »
« Reply #10 on: May 22, 2021, 08:13:35 am »
...using this calculator:
A significant oversight / failing of such calculators in my view is that they make no distinction between the various rating systems used to determine anode dissipation limits, ignoring the expectation / intention of the rating system designers that limits provided under the design max and absolute max systems should have a suitable de-rating applied before being used in such calculations.
« Reply #11 on: May 22, 2021, 08:17:03 am »
Wrong. You had it right to begin with.
« Reply #12 on: May 22, 2021, 01:48:57 pm »
the math is faster than web pages loading  :icon_biggrin:
Vk (cathode) / Rk = tube current
Vp EDIT: - Vk * tube current = watts dissipated
(built in fudge factor because I didn't subtract G2:)
« Last Edit: May 22, 2021, 05:23:34 pm by shooter »
« Reply #13 on: May 22, 2021, 02:58:34 pm »
Vp* tube current = watts dissipated
Need to subtract Vk from Vp  :icon_biggrin:
Offline Latole
« Reply #14 on: May 22, 2021, 03:29:45 pm »
That is what I do.
