September 20, 2026, 07:50:48 am
Hoffman Amps Forum image Author Topic: Lar/Mar PPI-MV question  (Read 8395 times)
Offline jackplug1
« on: May 23, 2021, 09:04:33 am »
Will this work for cathode bias?
Which works best, Audio or Linear taper?
Re: Lar/Mar PPI-MV question
« Reply #1 on: May 23, 2021, 09:55:44 am »
Will this work for cathode bias?   yes
Which works best, Audio or Linear taper?   your choice
This circuit can be simplified. Search some more.
Offline jackplug1
« Reply #2 on: May 24, 2021, 05:20:36 am »
Do you mean this?:
« Reply #3 on: May 24, 2021, 07:23:49 am »
Yes, that should work fine  :thumbsup:
If the application is to get overdrive at domestic friendly SPLs, then an audio taper pot would be best.
Whereas if you're just a tiny bit too loud for your band and being able to turn it down a touch would be handy, then a linear taper may be better. But it would be a hair trigger between 0-1 to get domestic SPLs with a linear pot.
Offline jackplug1
« Reply #4 on: May 24, 2021, 08:31:07 am »
Okay - thanks for that
Offline jackplug1
« Reply #5 on: May 26, 2021, 11:50:54 am »
Will implimenting this modification (Lar/Mar PPI-MV) affect the brilliant control, should I remove that pot and cap altogether ( I don't care for it anyway)
See attached diagram
« Reply #6 on: May 26, 2021, 04:51:41 pm »
No, the LarMar won’t affect the brilliant control, provided that the you wire the brilliant control before (on the hot side) of the LarMar.
Offline jackplug1
« Reply #7 on: May 28, 2021, 11:51:03 am »
I have attached some diagrams and would be grateful if somebody could check them out to see if they are correct.
I have removed the 220k resistors  from the original schematic
« Reply #8 on: May 28, 2021, 12:57:02 pm »
The brilliant control is wired up incorrectly. The cap should be in series with the control's variable resistance. The sketch puts it in parallel.
Offline jackplug1
« Reply #9 on: May 28, 2021, 02:04:17 pm »
Thank you, I will correct that
Offline jackplug1
« Reply #10 on: June 04, 2021, 08:00:03 am »
After correcting that I wired it up. The MV works very well but the brilliant control causes distortion at when rotated completely counter clockwise for some reason.
Offline Fresh_Start
  • noob de Lux
« Reply #11 on: June 07, 2021, 12:51:41 pm »
I would simply take it out since you didn't like it pre-modifications anyway.
Is it possible that the 470pf cap in the "Brilliant" circuit got too much heat at some point during the process?  I don't know that it's the problem but that would be my first suspect.
I wish that I had a clever way to use that pot for something else but nothing comes to mind.  A Mid control always is nice IMHO; however, it would take some work to design and implement one in this amp.
Cheers,
Chip
« Last Edit: June 07, 2021, 12:59:38 pm by Fresh_Start »
Quote from: jjasilli
Quote from: PRR
« Reply #12 on: June 07, 2021, 01:18:06 pm »
That seems weird. Is CCW max or min resistance?
Does the setting of the master vol affect the distortion?
