September 19, 2026, 05:06:12 pm
Hoffman Amps Forum image Author Topic: Loud high pitched noise  (Read 9216 times)
Offline pda041376
« on: June 06, 2021, 11:11:15 am »
I have been playing the amp, put an hour on it this morning. Move the amp to changed speaker in cabinet it was on. Got the speaker changed, fired the amp up and got a full volume sort of high pitched constant drone as soon as flipped off of standby. Turned gain and volume down trod again, same result. I figured maybe the speaker was the issue but hooked cabinet to a different amp and it works perfectly. Changed amp to speaker cord to the one used with the working amp, same thing: loud constant tone, not a simple hum or buzz, sounds like a test tone gone wrong, as soon as flipped off of standby.
Flipped chassis over and do not see any immediately visible issues with speaker output jack solder joints.
The speaker that was changed was an 8 ohm Jensen and replaced with an 8 ohm eminence.
Any suggestions as to where to focus?
Offline dude
Re: Loud high pitched noise
« Reply #1 on: June 06, 2021, 11:14:05 am »
Switch the OT plates wires on power tubes, ? Put the other speaker back in first and try.
« Last Edit: June 06, 2021, 11:16:50 am by dude »
Offline pda041376
« Reply #2 on: June 06, 2021, 11:35:04 am »
I'll definitely try the old speaker when I get back to house. Not sure why plate wires would need moved?
« Reply #3 on: June 06, 2021, 12:39:56 pm »
since there's NO schematic or amp information, "we're" assuming a PP amp with NFB.  IF the wires are "wrong"  then you are feeding back positive - in phase signal, which send the amp into infinite gain
Offline pda041376
« Reply #4 on: June 06, 2021, 12:52:26 pm »
It is PP with NFB, I was asking why switch wires on tubes if amp was wiring an hour prior.
In any case, tried old speaker and the noise is not there, triee with new again and it is there. Again like a test tone but at full volume.
As far as amp info, kld JCM25 kit, not the pcb variant. Has worked fine for a couple months. What would cause one speaker (mod 12/50 8ohm) to not cause the issue and another (eminence gov 75 w 8 ohm) to cause it? Could it be the issue was always there and the mod just wasn't affected? Set positive to positive and neg to neg when replacing.
Offline pda041376
« Reply #5 on: June 06, 2021, 01:15:55 pm »
And just tried swapping the pos/neg speaker connection, still gets the crazy sound but still not crazy sound on old speaker... At a loss as to how speakers of same resistance can cause this.
Offline pda041376
« Reply #6 on: June 06, 2021, 01:24:30 pm »
And just tried the 4 ohm jack to see if it might be speaker is mislabeled. Different sound, very high pitched squeal as opposed to test tone. And yes the old, cheap speaker still works as it always did. Dumbfounded
« Reply #7 on: June 06, 2021, 01:59:14 pm »
this happens with NO input signal?
IF SO, pull V1, change?
IF NO, pull V2, any change?
IF NO.......
stop before the PI tube
disconnect NFB, any change?
Offline pda041376
« Reply #8 on: June 06, 2021, 02:02:23 pm »
Correct, no input, volume 0, gain 0 and yet wails like a banshee after flipping off standby. Not instantly, maybe 3 to 5 seconds then wailing starts.
Will pull tubes in order and report back but stumped as to why, even right now, I can hook old speaker back up and it works the same as it did this morning prior to speaker change.
Offline pda041376
« Reply #9 on: June 06, 2021, 03:07:55 pm »
Further test, hooked up to another speaker outside the cabinet (celestion g12 v type, 70w, 8 ohm) and ko nose there. Going to try to jumper past the input jack on cabinet and try eminence direct that way.
Offline pda041376
« Reply #10 on: June 06, 2021, 03:14:13 pm »
So odd... Clipped wires, direct connected to the eminence and still does it. Other amps work with the eminence and other speakers work with this amp. Guess this amp just does not like the eminence, period. I don't understand it but guess I'll just have to use a different speaker in this cab.
Offline pda041376
« Reply #11 on: June 06, 2021, 03:21:56 pm »
Or not. As soon as try to play anything any speaker goes crazy feedback sounding, high pitched whine with no other sound coming through. This kills me since I know it was working absolutely fine this morning.
Offline pda041376
« Reply #12 on: June 06, 2021, 03:23:19 pm »
IF NO.......
Unreal, changed power tubes to so seriously old Sylvanias instead of the 2 month old groove tubes and it works. WTF?
Offline pda041376
« Reply #13 on: June 06, 2021, 03:26:08 pm »
Scratch that. *worked* for about 5 minutes then the test tone came back. Blah.
« Reply #14 on: June 06, 2021, 07:41:26 pm »
going back to my planet, enjoy  :icon_biggrin:
Offline pda041376
« Reply #15 on: June 06, 2021, 08:12:23 pm »
Thanks for chase points, breaking out iron tomorrow to hit joints an DC NFB.
« Reply #16 on: June 07, 2021, 04:34:03 am »
The stability of your amp seems to be marginal, ie with some conditions it’s stable, but change the conditions slightly and it oscillates.
Note that the impedance - frequency chart of all speakers differs. Do a bit of research by obtaining it for the speakers in question. You may need to request it, or it may be published on the manufacturer’s website. The higher the impedance peak at bass resonance, the higher the amplifier gain at that point.
The relevance being that when connected to speakers with a smaller bass resonance peak, the amp may not have quite enough gain to oscillate, whereas when connected to a speaker with a bigger bass resonance peak, it does.
So the feedback loop may be positive rather than negative.
« Last Edit: June 08, 2021, 05:07:46 am by pdf64 »
Offline eggbert
« Reply #17 on: June 07, 2021, 12:47:12 pm »
Are you using shielded wire for the grids?  Happened to me once. The shielded was bad/ or caused oscillation and created bad squeal. I replaced the grid wires with solid core 600v wire and it worked fine. Might not be your issue but worth a try.
« Reply #18 on: June 07, 2021, 02:26:14 pm »
Without a picture who knows..
Offline pda041376
« Reply #19 on: June 10, 2021, 06:21:03 pm »
Well, swapped v3 and spot-checked/reflowed some solder joints. Quieter now than it ever was. Decided I needed to know actual cause so popped old v3 back in and sure enough the noise came back. Chalk it up to a bad tube. Thanks all.
Offline dude
« Reply #20 on: June 11, 2021, 04:42:14 pm »
Hum...? usually checking tubes is one of the first things done, saves a lot of unnecessary diagnosing.
Offline pda041376
« Reply #21 on: June 13, 2021, 10:44:53 am »
Agreed, still learning. I know I should have checked the easiest thing first but was perplexed because it was working earlier that day and after I changed out a speaker in the cab it went wonky. Was thinking the speaker might have been a factor but know better now to always check tubes when freak stuff happens.
