September 20, 2026, 01:17:55 am
Hoffman Amps Forum image Author Topic: Canadian jcm800 2203 heater fuses  (Read 4155 times)
Offline phsyconoodler
« on: June 09, 2021, 11:23:23 pm »
Canadian issue 2303s have 5amp heater fuses mounted inside with the HT fuses as well. Is there any downside to bypassing these heater fuses? I mean normal 2203s don't have them and they seem to survive just fine.
Offline Latole
Re: Canadian jcm800 2203 heater fuses
« Reply #1 on: June 10, 2021, 03:11:52 am »
In my opinion you have the answer, the fuse is not necessary.
Most amps, no matter the manufacturer, do not have a heater fuse. But it is an additional protection.
You can bypass it if you have no issue with tubes heater.
If fue blow and you don't have spair, it is another story.
« Reply #2 on: June 10, 2021, 04:31:58 am »
Bypassing fuses doesn’t cause a problem until it does. In that event, if a fire etc incident occurs, fire investigators will be examining such things closely. It may transpire that there’s criminal  liability to answer.
Offline Latole
« Reply #3 on: June 10, 2021, 06:44:07 am »
I will alway keep amp as original desing, don't by pass it, or did it only for test purpose
