September 28, 2026, 05:15:14 pm
Hoffman Amps Forum image Author Topic: Beltone Tremolo Depth?  (Read 4460 times)
Offline kerobit
« on: July 03, 2021, 06:35:32 pm »
I've put this style of tremolo in an amp project I'm working on, as well as the same V1 cathode setup, and I'm trying to figure out if its possible to increase the depth/intensity? I've been changing resistor values on a decade box but can't seem to find anything that makes it larger? It may have a higher limit based on the tube itself since its wiggling the bias?
Re: Beltone Tremolo Depth?
« Reply #1 on: July 03, 2021, 11:03:35 pm »
Try making the 250K at "C" 100K.
However this is basically as cheap a trick as will work at all. It may be greedy to also ask for "more".
Offline kerobit
« Reply #2 on: July 04, 2021, 01:49:36 pm »
Thanks I'll give that a go.
I also realized I'm running a 12ax7 in parallel for the first stage thats being wobbled, so I may need to change the cathode resistor/cap values to make it run better with that setup as well.
Update: That seems to have done the trick a little bit! Got enough that its at least useful now. Thanks!
« Last Edit: July 04, 2021, 06:11:52 pm by kerobit »
