September 30, 2026, 02:59:09 am
Hoffman Amps Forum image Author Topic: Bartell/hohner amp, bias question  (Read 6477 times)
Offline Stuff4bikes
« on: July 06, 2021, 01:27:55 am »
Anyone familiar with these? All I have is the chassis, no enclosure or speaker.
Can someone explain the bias method on this amp...I am fairly new to this stuff but I cant remember seeing this method.
« Last Edit: July 07, 2021, 09:04:46 pm by Stuff4bikes »
Offline Latole
Re: Picked up a bartell contessa ca 15
« Reply #1 on: July 06, 2021, 02:45:54 am »
https://bartell.vintageusaguitars.com/2021/05/19/ca-15-mini-bass/
Google ; " honer contessas CA 15 amp"  and you'll many informations
What are you looking for ? Is amp working or not ?
You want to add a speaker ? Any 8 ohms 20 watts (or more) speaker will work .
Whant to built cab ?
« Last Edit: July 06, 2021, 02:54:46 am by Latole »
Offline Stuff4bikes
« Reply #2 on: July 06, 2021, 07:43:49 pm »
Just some random question.....
It says bass amp....how does a guitar sound through it.....
How did the chassis mount originally.
I have noticed different variations online. Mine has a toggle and fuse on the front right side. Mine doesn't say hohner on the front.
Some had a 12" speaker or a 15"
They made a guitar and bass CA-15, it sounds like.....what's the difference....
Offline Stuff4bikes
Re: Bartell/hohner amp, bias question
« Reply #3 on: July 07, 2021, 09:07:29 pm »
I put a 2amp fuse in, powered it up with my dim bulb and it sounds pretty good. No hum that I hear.....everything looks factory except it looks like cap can was changed....
Offline st
« Reply #4 on: July 08, 2021, 12:42:21 am »
Fixed bias, it seems. But something's wrong in the supply on the schematic. Who drew that? Pics of actual circuitry?
Offline Stuff4bikes
« Reply #5 on: July 08, 2021, 02:15:40 am »
I got it from a bartell fan site. Its stated he owns this amp and several others and he drew/put the schematics on line.....
I will get some pics tomorrow of the circuitry.
Offline Latole
« Reply #6 on: July 08, 2021, 03:17:53 am »
It is a fixed bias.
AC voltage for bias circuit is wrong;
What it should be ;
Offline Latole
« Reply #7 on: July 08, 2021, 03:34:17 am »
Two modifications I would make would be to rewire the heater.
Unplug the ground side of the transformer and the heater side to install a wire. The two wires feeding the heaters should be twisted together.
I would add an artificial ground with two 100 to 220 ohms resistors. ( screen shot )  ; http://www.valvewizard.co.uk/heater.html
And I'll add 3 prong grounded power cord.
This modification would make the amp quieter and safer.
« Last Edit: July 08, 2021, 03:36:19 am by Latole »
« Reply #8 on: July 08, 2021, 11:50:22 am »
Pin 8 V2 is surely higher than 80V, more near 100V-110V DC. I dunno if the parts can drift that much or just a typo.
