September 16, 2026, 12:11:30 pm
Hoffman Amps Forum image Author Topic: Bugera V22 hum  (Read 5375 times)
Offline fossilshark
  • No life til' leather
Bugera V22 hum
« on: July 31, 2021, 12:29:21 am »
Hi, I have a Bugera V22 on the bench here and there was no audio when I first got it. After making sure all the voltages were correct I resoldered all the dogshit factory solder joints and that brought it back to life.
There is still a bad hum that is not affected by any controls other than master volume, and the hum gets really bad when its in pentode mode.
I am thinking it needs new power tubes, does this sound correct?
~SNOWBLIND~
Re: Bugera V22 hum
« Reply #1 on: July 31, 2021, 06:38:05 am »
If power tubes are causing hum the master volume would not affect the hum.
Offline mk_716
Re: Bugera V22 hum
« Reply #2 on: July 31, 2021, 10:02:18 am »
heads up fossilshark,
    I came by two of these, both with serious problems.   Check the wiring to the Triode/Pentode switch  - one of them I had a short/melted insulation in the wire bundle coming to the switch from the pcb.
I've gutted out the chassis (both) and am building other projects into them.   The transformers were good, nice cabinet, 12" speakers..
m.
Offline fossilshark
Re: Bugera V22 hum
« Reply #3 on: July 31, 2021, 11:56:40 am »
Thank you very much
~SNOWBLIND~
Offline fossilshark
Re: Bugera V22 hum
« Reply #4 on: August 01, 2021, 09:38:48 pm »
 :help:
So I checked the switch and wires and they seem fine.
The hum is only present when the master volume is turned up enough for signal to get through, but the hum does not get any louder or quieter with the master volume. Once its present no knob affects the hum.
Could it be the filter caps?
~SNOWBLIND~
Offline AmberB
Re: Bugera V22 hum
« Reply #5 on: August 02, 2021, 12:17:36 am »
Well, filter caps are a possibility at least...
Offline fossilshark
Re: Bugera V22 hum
« Reply #6 on: August 02, 2021, 04:32:10 am »
How would I check? Should I break out the O'scope and see if the hum is on b+?
~SNOWBLIND~
