September 25, 2026, 11:05:20 am
Hoffman Amps Forum image Author Topic: Coupling cap switch options  (Read 6848 times)
Offline echuta13
  • Elder God
« on: August 30, 2021, 02:39:47 pm »
I was interested in putting some feelers out on a better way to switch coupling caps (plus prevent popping and high voltage on the switch).
The graphic shows how I am currently doing the switch (which is okay), but the updated version I think would be better and maybe one less part...  Maybe..
Any thoughts or insights on this?  Should there be a resistor across the switch in the improved one as well?  I have also seen a 10M resistor placed between the caps going to ground to prevent any noise as well.
This is just pencil pushing for now.  Need to clean off the work-bench before I can actually mess with this.
"When choosing between two evils I always like to try the one I've never tried before."
Offline brewdude
Re: Coupling cap switch options
« Reply #1 on: August 30, 2021, 03:54:58 pm »
The updated version is similar to the way Dumble employed the mid boost function on his ODS’s.  I would suspect a large value resistor would be helpful to silence switching pops.
« Reply #2 on: August 31, 2021, 03:13:47 am »
A 10M resistor to reference each node to 0V should stop pops.
« Reply #3 on: August 31, 2021, 03:49:06 am »
Dumble style
Offline echuta13
  • Elder God
« Reply #4 on: August 31, 2021, 11:55:57 am »
Thanks everyone for the confirmation!
Offline roseblood11
    • Layouts and Pictures
« Reply #5 on: July 27, 2023, 09:17:43 am »
Why does Dumble do it like this? Leaving one side of the 390p unconnect in the "mid boost" position will cause some popping, right? Why doesn`t he leave the cap connected at both ends and just jumpers it wit the switch?
