September 13, 2026, 02:59:13 pm
Hoffman Amps Forum image Author Topic: Noise issue with princeton reverb  (Read 5794 times)
Offline rutledj
« on: August 31, 2021, 06:43:08 pm »
I built the princeton reverb found on this site. It sounds great, everything works as expected, but when I play certain notes (like the G on the low E string, 3rd fret), I get all kinds of static noise through the speaker. I've taken the chassis out of the cabinet and hooked it to an unmounted speaker to try to eliminate the cabinet and it still does it. I tap on the chassis (anywhere on it) and I get the static. I've tried new tubes, resoldered all wires and components.  Not really sure what else to try. Voltages all look good.
Any suggestions?
Offline labb
Re: Noise issue with princeton reverb
« Reply #1 on: August 31, 2021, 07:49:29 pm »
Double check all of your grounds.
« Reply #2 on: August 31, 2021, 08:28:08 pm »
bad connection somewhere
Offline labb
« Reply #3 on: August 31, 2021, 09:02:22 pm »
I would "chop Stick" every connection see if you can make it make the noise.
« Reply #4 on: August 31, 2021, 09:55:25 pm »
> certain notes
Can you hold those notes? Friend? Signal generator?
Then take a rubber-ended pencil and try holding it various places to damp the mechanical vibration.
Offline rutledj
« Reply #5 on: September 01, 2021, 06:07:21 am »
Good idea with the signal generator. I'll try that. Have one I built over 35 years ago in tech school!
Offline rutledj
« Reply #6 on: September 07, 2021, 12:54:01 pm »
Well, spent the last week completely taking the amp apart, replaced every wire, put in brand new tube sockets, re-soldered every connection, tightened down every pot and jack, put in new tubes and tried a different speaker.. Dang thing still has that static noise on certain notes. Tapping almost anywhere on the chassis, board, or any tube will also create the static. Completely disillusioned at this point. Have no idea what to try next.
« Reply #7 on: September 07, 2021, 01:43:54 pm »
Hello, have you tried a different instrument cord and guitar? Also you prolly need to try different tubes.  Does it do this with the reverb driver V2 pulled ?
Oops   reread and see you tried different tubes.
« Last Edit: September 07, 2021, 01:49:48 pm by mresistor »
Offline ac427v
« Reply #8 on: September 07, 2021, 07:34:23 pm »
You have already tried a ton of ideas. Persistence is the only answer I can offer. Once I had a volume pot that got solder or flux inside and showed that symptom. I was chopsticking it for the 11th time when I finally noticed that pushing on one of the pot terminals made a little static. New pot was the permanent solution. Good luck with your brain-teaser.
« Reply #9 on: September 08, 2021, 12:03:46 pm »
I think I'd find a spot of the fretboard where it consistently makes the static sound and adjust every pot one at a time and see if it goes away.  Static as you describe it has also in my experience been a cracked or insufficient solder joint of a ground termination and would make the noise when there was physical vibration or shock, like you describe.  It could also do it with sympathetic vibration from a certain frequency being played on the guitar.  Some pictures of the inside of your amp could be helpful.
