September 14, 2026, 02:00:36 pm
Hoffman Amps Forum image Author Topic: New tubes vs. Used tubes  (Read 4718 times)
Offline Rickinbeachcrest
« on: September 17, 2021, 01:32:12 pm »
I've been looking through ebay and noticed a lot of used vintage tubes that test good.
Any thoughts on this?
Thanks.
Rick
Re: New tubes vs. Used tubes
« Reply #1 on: September 17, 2021, 01:42:57 pm »
buyer beware
Offline thetragichero
« Reply #2 on: September 17, 2021, 02:19:51 pm »
definitely buyer beware, but can be a good way to scoop up some old tubes. better when the listing includes the tube tester they've used along with readings, but who knows if it's calibrated correctly. best tube tester (besides testing for shorts) is an amp
Offline Williamblake
« Reply #3 on: September 17, 2021, 03:28:10 pm »
They may test good but make noise etc. I buy cheap only and run them all through a working amp and write down a signifcant value eg cathode voltage to be able to compare them and also mark the noisy ones if they are preamp pentodes. This may seem impractical but i dont want to have an amp with expensive tubes i cant replace anyway.
Offline dragonworks
« Reply #4 on: September 19, 2021, 07:41:45 am »
When you need 7189As there doesn't seem to be much choice?
Offline 66Strat
« Reply #5 on: September 19, 2021, 09:27:11 am »
NOS 7189A tubes are still available from reputable tube dealers. Not cheap, but available.
https://www.kcanostubes.com/catalog/31
The 6p14p-ev tube is a viable substitute.
https://frank.pocnet.net/sheets/113/6/6P14P.pdf
NOS 6p14p-ev tubes are still available, but prices are rising.
New Sensor continues to make this tube and markets it as the Sovtek EL84M and/or the Tung-Sol 7189.
Regards,
JT
Offline dragonworks
« Reply #6 on: September 19, 2021, 09:53:27 am »
Right now I have about 16 of them. I have stocked up. Didn't know they were available new.
Offline dude
« Reply #7 on: September 19, 2021, 04:18:53 pm »
I’ve had decent luck with used vintage tubes on eBay, trusting the spoken condition is another matter.  So, l only buy when in lots and cheap. I test them in an amp, usually with fixed bias so l can at least read the bias voltage: if this voltage is consistent, the  tubes usually sound good. I’ll match power tubes this way on bias current, works well for me.
