September 14, 2026, 10:49:13 am
Hoffman Amps Forum image Author Topic: Sluckey's Smoky whith paralleled pentode at input  (Read 4606 times)
« on: September 28, 2021, 05:32:29 pm »
Assuming you wont to reporpose Sluckey's Smoky L'il Toaster with 3 paralleled 5654/6AK5 tubes as input and drive with them a TMB ToneStack
which will be your way to parallel the input ?
Many Thanks
« Last Edit: September 28, 2021, 05:36:04 pm by kagliostro »
Re: Sluckey's Smoky whith paralleled pentode at input
« Reply #1 on: September 29, 2021, 07:03:42 am »
Franco,
On the Tweed Overdrive Special that DaGeezer and I worked on many years ago,  we both tried paralleling a 5879 & 5654 or 6AU6 in the first gain stage.
I had a 5879 9pin socket and a 7pin socket for the 5654 both available for a paralleled V1 type 1st gain stage.
I did play it that way for some time with both 5879 & 5654 paralleled but after some time I decided I liked the tone of one of those at a time more than them paralleled. I thought the 5654 sounded close to as good as the 5879, FWIW.
Just offering my thoughts on that experiment. Bottom line is the paralleling added a little oomph but not enough good musical tone to make it worthwhile.
The
« Reply #2 on: September 29, 2021, 09:05:30 am »
Ciao Jeff
Thanks for the answer
my interest Is about to have enough signal to be able to drive without excessive loss the TMB ToneStack
I have a lot of those small little tubes and the idea Is to use 3 of them paralleled, so no other kind of tube in parallel for tone variations
Thanks again
« Reply #3 on: September 29, 2021, 11:27:26 am »
This is pretty much how I did it with paralleled pentodes on the TOS.
« Reply #4 on: September 29, 2021, 02:58:51 pm »
Thanks again
So your choice will be a direct junction of the two pentodes without the use of mixing resistor
no mixing resistors = no signal drop, that is what I prefer
