September 16, 2026, 11:30:42 am
Hoffman Amps Forum image Author Topic: Bias help  (Read 7404 times)
Offline joesatch
  • save me from myself.
Bias help
« on: October 16, 2021, 01:12:58 pm »
Got this Robinette jj 6V6S jcm800 put together. No issues , sounds great.  The bias is cold, very cold. With the bias pot at the hottest setting, i'm getting -70v at the Grid, the other way gets it to -80's.  My plate/screen voltages are 565V.
Re: Bias help
« Reply #1 on: October 16, 2021, 02:14:06 pm »
Increase the 470Ω bias range resistor. I suggest 1K to begin with. Then increase/decrease for the exact voltage you want.
I would set the bias and balance pot to middle of rotation and change the bias range resistor to give -35V on the grids of the 6V6s.
Offline joesatch
Re: Bias help
« Reply #2 on: October 16, 2021, 02:34:10 pm »
the only 1k i have on hand is one of these. Physically it will fit with no issues. It measures 1k exactly.
https://www.tubesandmore.com/products/resistor-5-watt-cemented-wirewound-5-tolerance-1k
Re: Bias help
« Reply #3 on: October 16, 2021, 02:35:25 pm »
Well, whatcha waiting on?  :icon_biggrin:
Offline joesatch
Re: Bias help
« Reply #4 on: October 16, 2021, 02:50:01 pm »
got it down a very small amount. -67.1
Re: Bias help
« Reply #5 on: October 16, 2021, 02:56:23 pm »
So, what's your next move?
BTW, I would not trim resistor leads until you find the magic value.
Offline joesatch
Re: Bias help
« Reply #6 on: October 16, 2021, 02:59:57 pm »
I'm thinking of changing the bias pot or the resistors on it
Re: Bias help
« Reply #7 on: October 16, 2021, 03:04:00 pm »
You're not paying attention! THAT ONE RESISTOR IS THE ONLY THING YOU NEED TO MESS WITH.
Offline joesatch
Re: Bias help
« Reply #8 on: October 16, 2021, 03:06:10 pm »
how high can i go with it? why is it going to be so far off from the layout/schematic?
Re: Bias help
« Reply #9 on: October 16, 2021, 03:08:27 pm »
There are no limits. Take it as high as needed. How much AC voltage do you measure at the PT lead where it connects to that resistor?
Offline joesatch
Re: Bias help
« Reply #10 on: October 16, 2021, 03:14:52 pm »
63.6vac
Re: Bias help
« Reply #11 on: October 16, 2021, 03:23:13 pm »
Rob only used 50VAC. Try 5K, 4K, 3K, 2K. If voltage does not come down to -35V, then you probably have a wiring error on the pots.
Offline joesatch
Re: Bias help
« Reply #12 on: October 16, 2021, 03:36:41 pm »
crap crap crap. I got the bias pot and the balance pot mixed up. I assumed the larger pot was the bias. No!
« Last Edit: October 16, 2021, 03:42:23 pm by joesatch »
Offline joesatch
Re: Bias help
« Reply #13 on: October 16, 2021, 04:27:22 pm »
got the 5.6k in there. range is -32 to -55 on the bias pot we are good there. I have them at -38 now and it all seems to be good. How do i measure ma on these tubes?
Re: Bias help
« Reply #14 on: October 16, 2021, 04:43:35 pm »
Easy way... Remove the jumpers between pins 1 and 8 on both output tubes. Move the ground wire from pin 8 to pin 1 on the left tube (looking at layout). Install a 1Ω 1W 1% resistor between pin 1 and pin 8 on both sockets. Measure millivolts on pin 8 of each tube. The millivolts corresponds to milliamps, ie, 25mV equals 25mA.
Offline joesatch
Re: Bias help
« Reply #15 on: October 16, 2021, 05:01:16 pm »
would that stay in permanently or just to measure?
Re: Bias help
« Reply #16 on: October 16, 2021, 05:13:55 pm »
You don't really need an answer to that, do you?
